Logitech G X56 HOTAS Throttle LED Board Replacement
    1. Logitech G X56 HOTAS Throttle LED Board Replacement, Label Plate: step 1, image 1 of 2 Logitech G X56 HOTAS Throttle LED Board Replacement, Label Plate: step 1, image 2 of 2
      • Remove the eight 8.6 mm long 1.5 mm hex screws from the label plate.
      Ask FixBot
    2. Logitech G X56 HOTAS Throttle LED Board Replacement: step 2, image 1 of 1
      • Use an opening tool to pry off the mode switch knob.
      Ask FixBot
    3. Logitech G X56 HOTAS Throttle LED Board Replacement: step 3, image 1 of 3 Logitech G X56 HOTAS Throttle LED Board Replacement: step 3, image 2 of 3 Logitech G X56 HOTAS Throttle LED Board Replacement: step 3, image 3 of 3
      • Remove the eight 12.5 mm long Phillips #1 screws from the underside of the label plate.
      • These screws are plastic! Be very careful when applying force.
      Ask FixBot
    4. Logitech G X56 HOTAS Throttle LED Board Replacement: step 4, image 1 of 2 Logitech G X56 HOTAS Throttle LED Board Replacement: step 4, image 2 of 2
      • Place the throttle right side up again, using the bottom panel as a coaster.
      • Gently pry the label plate from the body of the throttle.
      Ask FixBot
    1. Logitech G X56 HOTAS Throttle LED Board Replacement, Motherboard: step 5, image 1 of 2 Logitech G X56 HOTAS Throttle LED Board Replacement, Motherboard: step 5, image 2 of 2
      • Optional: Take a picture or mark each connector as you remove them for ease of reassembly.
      • Disconnect all of the motherboard connectors by pulling them straight up and out of their sockets.
      Ask FixBot
    2. Logitech G X56 HOTAS Throttle LED Board Replacement: step 6, image 1 of 2 Logitech G X56 HOTAS Throttle LED Board Replacement: step 6, image 2 of 2
      • Remove the four 11.6 mm-long Phillips #0 screws that secure the motherboard.
      Ask FixBot
    3. Logitech G X56 HOTAS Throttle LED Board Replacement: step 7, image 1 of 1
      • Lift the motherboard from the base plate shell, carefully making sure to keep the USB power cable unstrained.
      Ask FixBot
    1. Logitech G X56 HOTAS Throttle LED Board Replacement, LED Board: step 8, image 1 of 2 Logitech G X56 HOTAS Throttle LED Board Replacement, LED Board: step 8, image 2 of 2
      • Each LED Board uses the LEDs to hold it against the base plate. It also has a single cable set to the logic and power board.
      Ask FixBot
    2. Logitech G X56 HOTAS Throttle LED Board Replacement: step 9, image 1 of 2 Logitech G X56 HOTAS Throttle LED Board Replacement: step 9, image 2 of 2
      • Each of the LEDs needs to be removed with a soldering iron and your choice of solder wick or solder sucker.
      • Once free of the solder, the LED must be pushed through to the front.
      Ask FixBot
    3. Logitech G X56 HOTAS Throttle LED Board Replacement: step 10, image 1 of 1
      • Gently Remove the LED board.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 41
All Time: 387
