Logitech G X56 HOTAS Joystick Tension Spring Replacement
  1. Logitech G X56 HOTAS Joystick Tension Spring Replacement, Tension spring: step 1, image 1 of 2 Logitech G X56 HOTAS Joystick Tension Spring Replacement, Tension spring: step 1, image 2 of 2
    • Turn the locking bezel counterclockwise until the joystick comes away from the base.
    Ask FixBot
  2. Logitech G X56 HOTAS Joystick Tension Spring Replacement: step 2, image 1 of 2 Logitech G X56 HOTAS Joystick Tension Spring Replacement: step 2, image 2 of 2
    • Remove the plastic ring by applying pressure and lifting equally on both sides.
    Ask FixBot
  3. Logitech G X56 HOTAS Joystick Tension Spring Replacement: step 3, image 1 of 2 Logitech G X56 HOTAS Joystick Tension Spring Replacement: step 3, image 2 of 2
    • There is a locking clamp that locks the spring that splits in two. Take one half of the clamp off, press the spring down, and take the other clamp out.
    • The spring is under compression and pops out if not done carefully.
    Ask FixBot
  4. Logitech G X56 HOTAS Joystick Tension Spring Replacement: step 4, image 1 of 1
    • Replace the old spring.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
1 Guide Comment
thanks for this tutorial but i can't do it in reverse
Azeratile _yt - Reply Share
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 139
All Time: 1,545
