Introduction
This guide is for replacing the LiPo Rechargeable Battery Logitech G Pro X Lightspeed. You battery may need to be replaced if your headset only turns on when plugged in or doesn't hold a long charge (factory spec is ~20 hours).
For your safety, discharge the battery below 25% before disassembling your device. Inspect batteries for physical and chemical damage. Battery should not be swollen to any extent. For non-OEM batteries, make sure your wires match with the original.
Prepare headset. Remove mic and set power switch to off
Replacement part #533-000084. 1100mAh 3.7V 603450 Li-polymer battery
Tool used on this step:Tweezers$4.99
Disconnect JST connector carefully using tweezers. Do NOT pull on the wires directly.
4 other people completed this guide.
5 Guide Comments
Que colores son los de la batería
Hey! Where can I find the replacement battery mentioned? Is the number mentioned (533-…) a reference to somewhere where I can buy it? Thank you!
As of last I checked, there is no official source. As long as the battery matches the voltage, wiring, and dimensions (603450) there should be no issues.
What's the best way to remove the battery from the adhesive and then the best way to have the new battery stick in place? Thanks
