Logitech G Cloud Wi-Fi Chip Replacement
    1. Logitech G Cloud Wi-Fi Chip Replacement, Case: step 1, image 1 of 2 Logitech G Cloud Wi-Fi Chip Replacement, Case: step 1, image 2 of 2
      • Power the device off and turn it over so the screen is face down.
      • Insert an opening pick into the seam between the back plate and left handguard.
      • Pry around the entire perimeter until the handguard fully releases.
      • Remove the handguard.
      • Repeat the previous three bullets on the right handguard.
      Ask FixBot
    2. Logitech G Cloud Wi-Fi Chip Replacement: step 2, image 1 of 1
      • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
      Ask FixBot
    3. Logitech G Cloud Wi-Fi Chip Replacement: step 3, image 1 of 2 Logitech G Cloud Wi-Fi Chip Replacement: step 3, image 2 of 2
      • Insert an opening pick into the seam between the midframe and rear case.
      • Gently pry the rear case upwards to separate it from the midframe.
      Ask FixBot
    4. Logitech G Cloud Wi-Fi Chip Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
      Ask FixBot
    5. Logitech G Cloud Wi-Fi Chip Replacement: step 5, image 1 of 2 Logitech G Cloud Wi-Fi Chip Replacement: step 5, image 2 of 2
      • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
      • Gently pry out the midframe by lifting an opening pick.
      • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
      Ask FixBot
    1. Logitech G Cloud Wi-Fi Chip Replacement, Wi-Fi Chip: step 6, image 1 of 2 Logitech G Cloud Wi-Fi Chip Replacement, Wi-Fi Chip: step 6, image 2 of 2
      • Use a Phillips #00 screwdriver to remove all four 10 mm screws that secure the Wi-Fi chips located on the top and bottom of the device.
      • Pop the Wi-Fi chips out with your fingers.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 42
All Time: 460
