Up to 20% off select tools
Logitech G Cloud Case Replacement
View statistics:
Past 24 Hours:
9
Past 7 Days:
28
Past 30 Days:
112
All Time:
913
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Replacing the case for the Logitech G Cloud is simple and can be accomplished in three steps. You will need a wedge tool and a Phillips #00 screwdriver. Carefully read the instructions before starting to disassemble the Logitech G Cloud. You may hear loud popping noises when you remove the casing.
    1. Logitech G Cloud Case Replacement, Case: step 1, image 1 of 2 Logitech G Cloud Case Replacement, Case: step 1, image 2 of 2
      • Power the device off and turn it over so the screen is face down.
      • Insert an opening pick into the seam between the back plate and left handguard.
      • Pry around the entire perimeter until the handguard fully releases.
      • Remove the handguard.
      • Repeat the previous three bullets on the right handguard.
      Ask FixBot
    2. Logitech G Cloud Case Replacement: step 2, image 1 of 1
      • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
      Ask FixBot
    3. Logitech G Cloud Case Replacement: step 3, image 1 of 2 Logitech G Cloud Case Replacement: step 3, image 2 of 2
      • Insert an opening pick into the seam between the midframe and rear case.
      • Gently pry the rear case upwards to separate it from the midframe.
      Ask FixBot
    4. Logitech G Cloud Case Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
      Ask FixBot
    5. Logitech G Cloud Case Replacement: step 5, image 1 of 2 Logitech G Cloud Case Replacement: step 5, image 2 of 2
      • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
      • Gently pry out the midframe by lifting an opening pick.
      • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
      Ask FixBot
Author
with
Spencer Davis
535 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 28
Past 30 Days: 112
All Time: 913
