Up to 20% off select tools
Logitech G Cloud Battery Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
127
All Time:
1,362
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Replacing the battery for the Logitech G Cloud is simple and can be accomplished in four steps. You will need a wedge tool and a Phillips #00 screwdriver. Avoid of using metal tools when removing the battery; instead, use the spudger as listed in the tool section. Carefully read the instructions before starting to disassemble the Logitech G Cloud. You may hear loud popping noises when you remove the interior plating.
For your safety, turn on your G Cloud and allow the battery to fully discharge before starting this procedure. A charged lithium-ion polymer battery can be very dangerous if accidentally punctured. Heating a charged battery is a fire hazard. If your battery looks puffy or swollen, take extra precautions.
    1. Logitech G Cloud Battery Replacement, Case: step 1, image 1 of 2 Logitech G Cloud Battery Replacement, Case: step 1, image 2 of 2
      • Power the device off and turn it over so the screen is face down.
      • Insert an opening pick into the seam between the back plate and left handguard.
      • Pry around the entire perimeter until the handguard fully releases.
      • Remove the handguard.
      • Repeat the previous three bullets on the right handguard.
      Ask FixBot
    2. Logitech G Cloud Battery Replacement: step 2, image 1 of 1
      • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
      Ask FixBot
    3. Logitech G Cloud Battery Replacement: step 3, image 1 of 2 Logitech G Cloud Battery Replacement: step 3, image 2 of 2
      • Insert an opening pick into the seam between the midframe and rear case.
      • Gently pry the rear case upwards to separate it from the midframe.
      Ask FixBot
    4. Logitech G Cloud Battery Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
      Ask FixBot
    5. Logitech G Cloud Battery Replacement: step 5, image 1 of 2 Logitech G Cloud Battery Replacement: step 5, image 2 of 2
      • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
      • Gently pry out the midframe by lifting an opening pick.
      • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
      Ask FixBot
    1. Logitech G Cloud Battery Replacement, Battery: step 6, image 1 of 3 Logitech G Cloud Battery Replacement, Battery: step 6, image 2 of 3 Logitech G Cloud Battery Replacement, Battery: step 6, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $8.95
      Buy
      • Insert the flat end of a spudger under the edge of the battery press connector and lift straight up to disconnect it.
      • Insert an opening tool under the bottom edge of the battery. Gently and slowly lift straight up to separate the adhesive on the battery from the console.
      • Take care not to bend, warp, or puncture the battery.
      • If your replacement battery doesn't come with adhesive, use a strong double-sided adhesive to secure it.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Spencer Davis
535 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 127
All Time: 1,362
