Up to 20% off select tools
Logitech Extreme 3D Pro USB Cable Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
102
All Time:
3,747
Comments: 10
4 comments on steps, 6 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
After extended use, the USB cable may have become frayed or broken completely. This will require you to change the cable to continue using the joystick.
    1. Logitech Extreme 3D Pro USB Cable Replacement, Disassembly of the handle: step 1, image 1 of 1
      • Remove these three Phillips #1 screws:
      • Two 10mm screws.
      • One 7mm screw.
      Ask FixBot
    2. Logitech Extreme 3D Pro USB Cable Replacement: step 2, image 1 of 1
      • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
      • Remove the two 10mm Phillips #1 screws.
      Ask FixBot
    3. Logitech Extreme 3D Pro USB Cable Replacement: step 3, image 1 of 2 Logitech Extreme 3D Pro USB Cable Replacement: step 3, image 2 of 2
      • Pull apart the joystick chassis by hand.
      • Release this clip located underneath the hand rest
      • The circuit board will be loose and may fall down.
      Ask FixBot
    1. Logitech Extreme 3D Pro USB Cable Replacement, Disassembly of the base: step 4, image 1 of 1
      • Remove the eight 10mm Phillips #1 screws from the bottom.
      Ask FixBot
    2. Logitech Extreme 3D Pro USB Cable Replacement: step 5, image 1 of 3 Logitech Extreme 3D Pro USB Cable Replacement: step 5, image 2 of 3 Logitech Extreme 3D Pro USB Cable Replacement: step 5, image 3 of 3
      • Flip the joystick upright.
      • Lift up the sliver base cover and feed the loose circuit board through.
      • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
      Ask FixBot
    1. Logitech Extreme 3D Pro USB Cable Replacement, USB Cable: step 6, image 1 of 2 Logitech Extreme 3D Pro USB Cable Replacement, USB Cable: step 6, image 2 of 2
      • Carefully pull from the plug head straight up.
      • It may require some force to remove the cable. However be careful not to damage the wires.
      Ask FixBot
2 other people completed this guide.
Author
with
Emanuel Canela
1,393 Reputation
7 Guides authored
USF Tampa, Team S7-G1, Passmore Spring 2018 Member of USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
4 Members
84 Guides authored
6 Guide Comments
What type of replacement cable do I need? Where can I purchase it?
Tom Tidbury - Reply Share
Along with Tom, I would also like to know where I can get replacement parts for this joystick. I’ve been searching for a while now and can’t seem to find any spare parts for this joystick.
Clayton Noyes - Reply Share
Savez-vous où l'on peut trouver cette pièce à l’achat ou à la récupération?
Jordan Stéphane Martinez - Reply Share
Hey! @thetechchild I had a similar issue, couldn't find replacement parts after my cat chewed on the cable.. So I found an alternate solution, I bought some of these cables, some heat shrink tubing, and replaced the cable like this. Now I can detach a male to male USB A cable to the joystick and replace the cheap cable if it ever gets damaged again! Make sure to plug the cables into the pin connector in the exact same way that the original cable was plugged in: Green, White, Red, thin Black, thicker Black (left to right as shown in the images I linked above). I think I could have gotten a JST XH plug to better connect it, but doing the pins directly seems to be working fine for now. I'm not entirely sure if that's the correct plug, but from my research it looks like it.
William McCall - Reply Share
Sadly same issue, tried all the linked products, looks like the design of the cables have changed. I cant get it to work even with the JST plug. Thanks for giving me a little hope though!
Dylan Brasier (Grim) - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 102
All Time: 3,747
