Logitech Extreme 3D Pro Disassembly of the handle
Views: 5.3K
View statistics:
Past 24 Hours:
Past 7 Days:
28
Past 30 Days:
138
All Time:
5,322
Comments: 5
2 comments on steps, 3 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
After extended use certain parts may require cleaning or replacement. This guide will assist you in safely disassembling the top handle portion of the joystick.
Tools
    1. Logitech Extreme 3D Pro Disassembly of the handle, Disassembly of the handle: step 1, image 1 of 1
      • Remove these three Phillips #1 screws:
      • Two 10mm screws.
      • One 7mm screw.
      Ask FixBot
    2. Logitech Extreme 3D Pro Disassembly of the handle: step 2, image 1 of 1
      • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
      • Remove the two 10mm Phillips #1 screws.
      Ask FixBot
    3. Logitech Extreme 3D Pro Disassembly of the handle: step 3, image 1 of 2 Logitech Extreme 3D Pro Disassembly of the handle: step 3, image 2 of 2
      • Pull apart the joystick chassis by hand.
      • Release this clip located underneath the hand rest
      • The circuit board will be loose and may fall down.
      Ask FixBot
6 other people completed this guide.
Emanuel Canela
1,369 Reputation
7 Guides authored
USF Tampa, Team S7-G1, Passmore Spring 2018 Member of USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
4 Members
84 Guides authored
3 Guide Comments
yeah but i got this far before looking at the site, and what i really want to see is how the cotter ring pin is set on the shaft that enables the z-rot instead of locking it down.
erock steady - Reply Share
if you havent worked it out already, the Z-rot spring needs spread across a little 3/8 inch tab, otherwise it will lock the axis a few degrees off center
cody Werdal - Reply Share
reassembling is tricky. The spring tabs for z-rot need to be aligned on one side of the handle and the z-rot potentiometer needs aligning on the other. There is nothing obvious in the handle design to guide the correct positioning. The difficult part is getting the pot tab to stay in its slot. If anyone knows of a technique to assist getting the handles halves and pot in the correct alignment, please do tell.
memar - Reply Share
Past 24 Hours: 1
Past 7 Days: 28
Past 30 Days: 138
All Time: 5,322
