Up to 20% off select tools
Logitech Dual Action disassembly
Views: 9.3K
View statistics:
Past 24 Hours:
7
Past 7 Days:
36
Past 30 Days:
151
All Time:
9,259
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
If your buttons are sticking and they cannot be cleaned from the outside, here is how you can clean it from the inside.
    1. Logitech Dual Action disassembly, Taking out the screws: step 1, image 1 of 1
      • To get into the controller, you will need to unscrew the 7 screws on the back.
      • You will have to remove the bottom oval sticker to reveal the screw circled in orange.
      Ask FixBot
    2. Logitech Dual Action disassembly, Opening the controller: step 2, image 1 of 3 Logitech Dual Action disassembly, Opening the controller: step 2, image 2 of 3 Logitech Dual Action disassembly, Opening the controller: step 2, image 3 of 3
      • With the screws removed, turn the controller upside down. Insert the iFixit opening tool between the top and bottom casing to pry them apart.
      • Separate the top and bottom casing.
      • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
      • There should be the four circular buttons labeled 1-4, four smaller circular buttons for the D-Pad, and three rounded rectangular buttons.
      Ask FixBot
    3. Logitech Dual Action disassembly, Cleaning the buttons: step 3, image 1 of 1
      • Turn the top casing of the controller over to remove all the buttons.
      • Wipe each individual button with a piece of cloth and rubbing alcohol.
      Ask FixBot
Finish Line
12 other people completed this guide.
Author
with
Brian Neuman
1,202 Reputation
3 Guides authored
USF Tampa, Team 7-4, Remmell Winter 2015 Member of USF Tampa, Team 7-4, Remmell Winter 2015
USFT-REMMELL-W15S7G4
4 Members
36 Guides authored
1 Guide Comment
What is the right side of dpad buttons when put back?
There a polish side and another with fabric numbers. What side have to be up and down?
rodrigomarshmallow - Reply Share
Past 24 Hours: 7
Past 7 Days: 36
Past 30 Days: 151
All Time: 9,259
