Up to 20% off select tools
Logitech Dual Action Triggers Repair
Views: 13K
View statistics:
Past 24 Hours:
6
Past 7 Days:
40
Past 30 Days:
186
All Time:
12,967
Comments: 5
1 comment on steps, 4 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Difficult
Tools
    1. Logitech Dual Action Triggers Repair, Logitech Dual Action Triggers Repair: step 1, image 1 of 1
      • To get into the controller, you will need to unscrew the 7 screws on the back.
      • You will have to remove the bottom oval sticker to reveal the screw circled in red.
      Ask FixBot
    2. Logitech Dual Action Triggers Repair: step 2, image 1 of 2 Logitech Dual Action Triggers Repair: step 2, image 2 of 2
      • With the screws removed, turn the controller upside down and separate the front end from the back end.
      • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
      Ask FixBot
    3. Logitech Dual Action Triggers Repair: step 3, image 1 of 1
      • There should be 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 oval shaped buttons.
      Ask FixBot
    4. Logitech Dual Action Triggers Repair: step 4, image 1 of 3 Logitech Dual Action Triggers Repair: step 4, image 2 of 3 Logitech Dual Action Triggers Repair: step 4, image 3 of 3
      • In the center of the controller, pull upwards on the USB cord.
      • Be careful not to pull hard enough to yank the wires connecting to the logic board.
      • With the wire out of the way, remove the screw it exposed. This will disconnect the logic board from the controller.
      Ask FixBot
    5. Logitech Dual Action Triggers Repair: step 5, image 1 of 3 Logitech Dual Action Triggers Repair: step 5, image 2 of 3 Logitech Dual Action Triggers Repair: step 5, image 3 of 3
      • To remove the triggers, push upwards from the back on them.
      • Once far enough, detach the logic board from the back cover piece and the triggers.
      Ask FixBot
    6. Logitech Dual Action Triggers Repair: step 6, image 1 of 2 Logitech Dual Action Triggers Repair: step 6, image 2 of 2
      • If the wire is unplugged solely from the logic board, you can fasten it back into its place.
      • Look at the second picture to see where the wires go.
      Ask FixBot
    7. Logitech Dual Action Triggers Repair: step 7, image 1 of 3 Logitech Dual Action Triggers Repair: step 7, image 2 of 3 Logitech Dual Action Triggers Repair: step 7, image 3 of 3
      • Unscrew the screw on the trigger to remove the back cover.
      • Once removed, carefully pull the back cover off.
      Ask FixBot
    8. Logitech Dual Action Triggers Repair: step 8, image 1 of 1
      • The 3 wires are soldered into the 3 spots circled on the picture.
      • You can now fasten the wire into the right spot on the trigger piece.
      Ask FixBot
8 other people completed this guide.
Author
with
Brian Neuman
1,202 Reputation
3 Guides authored
USF Tampa, Team 7-4, Remmell Winter 2015 Member of USF Tampa, Team 7-4, Remmell Winter 2015
USFT-REMMELL-W15S7G4
4 Members
36 Guides authored
4 Guide Comments
Hi dear, can you say me the order of colours in the USB cable? I think green, white, red, black thin and black thick. Is It correct?
Cas - Reply Share
Where can I get conductive pads for this?
Ginga - Reply Share
RADO rakotonatoandro - Reply Share
Past 24 Hours: 6
Past 7 Days: 40
Past 30 Days: 186
All Time: 12,967
