Up to 20% off select tools
Logitech Dual Action Joystick Replacement
Views: 16K
View statistics:
Past 24 Hours:
6
Past 7 Days:
41
Past 30 Days:
251
All Time:
15,515
Comments: 7
2 comments on steps, 5 guide comments.
Go to guide comments
Completed: 29
29 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
If the joystick on your Logitech Dual Action controller isn't working properly, refer to the guide to walk you through how to replace the joystick on your Logitech Dual Action controller.
The joystick is an essential part of any controller. A faulty joystick will result in difficulty navigating any software you may encounter where you will need the joystick.
Ensure your controller is disconnected from the power source before beginning your replacement.
    1. Logitech Dual Action Joystick Replacement, Taking out the screws: step 1, image 1 of 1
      • To get into the controller, you will need to unscrew the 7 screws on the back.
      • You will have to remove the bottom oval sticker to reveal the screw marked with orange.
      Ask FixBot
    2. Logitech Dual Action Joystick Replacement, Opening the controller: step 2, image 1 of 3 Logitech Dual Action Joystick Replacement, Opening the controller: step 2, image 2 of 3 Logitech Dual Action Joystick Replacement, Opening the controller: step 2, image 3 of 3
      • With the screws removed, turn the controller upside down and separate the front end from the back end.
      • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
      • There should be the 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 rounded rectangular buttons.
      Ask FixBot
    3. Logitech Dual Action Joystick Replacement, Replacing the joystick: step 3, image 1 of 2 Logitech Dual Action Joystick Replacement, Replacing the joystick: step 3, image 2 of 2
      • With the case off, the joysticks can be removed by pulling them upward.
      • To put the replacement joystick on, align the hole at the bottom of the joystick with the rectangular peg and gently push down.
      • Make sure that the cut-out side of the joystick is towards the outsides of the device.
      Ask FixBot
Finish Line
29 other people completed this guide.
Author
with
Brian Neuman
1,202 Reputation
3 Guides authored
USF Tampa, Team 7-4, Remmell Winter 2015 Member of USF Tampa, Team 7-4, Remmell Winter 2015
USFT-REMMELL-W15S7G4
4 Members
36 Guides authored
5 Guide Comments
Can the Analogue Stick be replaced with the One of XBOX 360 or PS3 Controller
shivam sah - Reply Share
will the buttons still work if you put it all back?
Atsuku - Reply Share
When you press the buttons, they don't work, but when you press hard, they only work, and they don't work just by pressing normally?
[deleted] - Reply Share
Merci pour le site.excusez moi pour le dérangement j'ai ma manette PS2 qui ne fonctionne pas quand je branche ça me dit que c'est pas connecté
Mohamed Abass Sylla - Reply Share
Past 24 Hours: 6
Past 7 Days: 41
Past 30 Days: 251
All Time: 15,515
