Up to 20% off select tools
Logitech Craft Battery Replacement
Views: 16K
View statistics:
Past 24 Hours:
12
Past 7 Days:
107
Past 30 Days:
476
All Time:
15,834
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace a worn-out or dead battery in your Logitech Craft wireless keyboard.
It’s natural for batteries to lose capacity as they age. If your keyboard dies quickly and doesn't hold a charge, it may be time to replace the battery.
For safety, perform this repair when your battery is below 15% charge. Any charged lithium-ion battery can be hazardous if punctured or damaged. If your battery looks puffy or swollen, take appropriate precautions.
    1. Logitech Craft Battery Replacement, Turn off the keyboard: step 1, image 1 of 1
      • Before you begin, flip the keyboard's power switch into the OFF position.
      • Unplug all cables from your keyboard.
      Ask FixBot
    2. Logitech Craft Battery Replacement, Remove the plastic foot: step 2, image 1 of 2 Logitech Craft Battery Replacement, Remove the plastic foot: step 2, image 2 of 2
      • Lay your keyboard down with the feet facing up on a clean work surface.
      • The dial will prevent the keyboard from laying perfectly flat. If you need to, lay the keyboard on a soft towel to prevent wobble.
      • Heat an iOpener and lay it on the left rear plastic foot for about two minutes.
      • Alternatively, you can also use a hair dryer to heat the sticker. Make sure it's on the Low setting to avoid warping the plastic.
      Ask FixBot
    3. Logitech Craft Battery Replacement, Remove the foot pad: step 3, image 1 of 3 Logitech Craft Battery Replacement, Remove the foot pad: step 3, image 2 of 3 Logitech Craft Battery Replacement, Remove the foot pad: step 3, image 3 of 3
      • Only one foot (the one next to the power switch) has a hidden screw underneath—you don't need to remove both feet.
      • Insert the point of a spudger under an end of the foot.
      • Push the spudger underneath the foot and lift until you can grip it with your fingers.
      • The foot should come away from the keyboard without much force. If it feels stuck, apply more heat and try again.
      • Peel the foot up and remove it.
      Ask FixBot
    4. Logitech Craft Battery Replacement, Remove the screw securing the bottom cover: step 4, image 1 of 2 Logitech Craft Battery Replacement, Remove the screw securing the bottom cover: step 4, image 2 of 2
      • If there's plastic film covering the screw, use the point of a spudger to poke through it.
      • Use a Phillips screwdriver to remove the 4.7 mm‑long screw securing the bottom cover.
      Ask FixBot
    5. Logitech Craft Battery Replacement, Unlock the bottom cover: step 5, image 1 of 2 Logitech Craft Battery Replacement, Unlock the bottom cover: step 5, image 2 of 2
      • The bottom cover is held in place by slotted plastic clips along the entire length of the keyboard.
      • Don't attempt to force the cover off until all clips have disengaged. The bottom cover should come away with little to no force.
      • Hold the keyboard upside down above your work surface.
      • Grip the bottom cover and slide it towards the ON/OFF switch to unlock it from the rest of the device.
      Ask FixBot
    6. Logitech Craft Battery Replacement, Slide and remove the bottom cover: step 6, image 1 of 3 Logitech Craft Battery Replacement, Slide and remove the bottom cover: step 6, image 2 of 3 Logitech Craft Battery Replacement, Slide and remove the bottom cover: step 6, image 3 of 3
      • Lay the keyboard back down onto your work surface.
      • Lightly push down on the bottom cover and slide it further towards the ON/OFF switch.
      • Remove the bottom cover.
      • During reassembly, make sure the bottom cover sits flush along the entire length of the keyboard—all clips need to lock back in place.
      Ask FixBot
    7. Logitech Craft Battery Replacement, Remove the foam pieces: step 7, image 1 of 3 Logitech Craft Battery Replacement, Remove the foam pieces: step 7, image 2 of 3 Logitech Craft Battery Replacement, Remove the foam pieces: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Various pieces of foam protect the battery wires and the interconnect ribbon cable. They'll need to be removed in order to access the battery.
      • Use a pair of tweezers to peel up and remove the first piece of foam covering the interconnect cable.
      • The foam pads are all secured with light adhesive.
      • Try your best to not rip these foam pads as you remove them—ideally they're reused during reassembly.
      Ask FixBot
    8. Logitech Craft Battery Replacement: step 8, image 1 of 2 Logitech Craft Battery Replacement: step 8, image 2 of 2
      • Remove the two remaining topmost pieces of foam from the keyboard.
      • Be very careful not to puncture the battery, as it can leak dangerous chemicals or catch fire.
      Ask FixBot
    9. Logitech Craft Battery Replacement, Remove the interconnect cable: step 9, image 1 of 3 Logitech Craft Battery Replacement, Remove the interconnect cable: step 9, image 2 of 3 Logitech Craft Battery Replacement, Remove the interconnect cable: step 9, image 3 of 3
      • Use the point of a spudger to gently lift the hinged locking flap on the interconnect cable's ZIF connector up and away from the cable.
      • Use a pair of tweezers to slide the interconnect cable out of its connector.
      • Try to grip the cable by the blue plastic, not by the cable itself.
      Ask FixBot
    10. Logitech Craft Battery Replacement: step 10, image 1 of 3 Logitech Craft Battery Replacement: step 10, image 2 of 3 Logitech Craft Battery Replacement: step 10, image 3 of 3
      • Use the point of a spudger to lift the hinged locking flap on the opposite end of the interconnect cable.
      • Remove the interconnect cable.
      Ask FixBot
    11. Logitech Craft Battery Replacement, Remove the rest of the foam: step 11, image 1 of 2 Logitech Craft Battery Replacement, Remove the rest of the foam: step 11, image 2 of 2
      • Use a pair of tweezers to remove the two remaining pieces of foam securing the battery wires.
      Ask FixBot
    12. Logitech Craft Battery Replacement, De-route the battery wires: step 12, image 1 of 3 Logitech Craft Battery Replacement, De-route the battery wires: step 12, image 2 of 3 Logitech Craft Battery Replacement, De-route the battery wires: step 12, image 3 of 3
      • Use a pair of tweezers to slide the battery wires out from underneath their plastic routing clips on either side of the battery.
      Ask FixBot
    13. Logitech Craft Battery Replacement, Disconnect both battery connectors: step 13, image 1 of 2 Logitech Craft Battery Replacement, Disconnect both battery connectors: step 13, image 2 of 2
      • Use a pair of tweezers to firmly grip the left battery connector.
      • Hold the tweezers with your fingers as close to the connector as possible to get a firm hold.
      • Gently rock the connector side‑to‑side and slide it straight out of the socket.
      • Always pull cables by their connectors and not the wires themselves.
      Ask FixBot
    14. Logitech Craft Battery Replacement: step 14, image 1 of 2 Logitech Craft Battery Replacement: step 14, image 2 of 2
      • Repeat the previous step to disconnect the right battery connector.
      • During reassembly, note that the battery connector that goes into the right board has three battery wires, and the left has two.
      Ask FixBot
    15. Logitech Craft Battery Replacement, Remove the battery: step 15, image 1 of 3 Logitech Craft Battery Replacement, Remove the battery: step 15, image 2 of 3 Logitech Craft Battery Replacement, Remove the battery: step 15, image 3 of 3
      • Insert the flat edge of a spudger underneath one of the short edges of the battery.
      • Push the spudger underneath the battery and lift, separating it from the adhesive holding it to the keyboard.
      • Make sure you push underneath the battery and not into it. Don't bend or deform the battery.
      • If the battery isn't separating, apply a few drops of isopropyl alcohol (>90%) to its edge and slightly tilt the keyboard. Wait one minute for the alcohol to soften the adhesive and try again.
      • Remove the battery.
      • To install a replacement battery:
      • Remove any leftover adhesive from the battery well.
      • Use double‑sided tape or pre-cut adhesive to secure the battery, making sure the battery is correctly oriented—the battery connector that goes into the right board has three battery wires, and the left has two.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
10 other people completed this guide.
Author
with
Carsten Frauenheim
174,985 Reputation
442 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
1 Guide Comment
fantastic instructions, where can I get a replacement battery?
Angel L Velazquez - Reply Share
Past 24 Hours: 12
Past 7 Days: 107
Past 30 Days: 476
All Time: 15,834
