Logitech Circle Speaker Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
103
All Time:
1,068
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will allow you to remove and replace the speaker inside of the Logitech Circle. This guide is relatively simple, but requires the removal of several screws and gently prying out the speaker from the base. Be sure to keep the screws organized for easier reconstruction.
Tools
    1. Logitech Circle Speaker Replacement, Speaker: step 1, image 1 of 2 Logitech Circle Speaker Replacement, Speaker: step 1, image 2 of 2
      • Wedge the plastic opening tool under the black circle lens to gently pry it off.
      • The lens is only attached with sticky tape and should remove relatively easily.
      Ask FixBot
    2. Logitech Circle Speaker Replacement: step 2, image 1 of 1
      • Remove the four 3mm Phillips #0 screws that hold down the first ring.
      Ask FixBot
    3. Logitech Circle Speaker Replacement: step 3, image 1 of 2 Logitech Circle Speaker Replacement: step 3, image 2 of 2
      • Remove the four 3mm Phillips #0 screws that hold down the second ring.
      Ask FixBot
    4. Logitech Circle Speaker Replacement: step 4, image 1 of 2 Logitech Circle Speaker Replacement: step 4, image 2 of 2
      • Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
      • The lens/battery bundle is attached to the base by a ribbon cable that can break, so be very careful handling the circle.
      Ask FixBot
    5. Logitech Circle Speaker Replacement: step 5, image 1 of 2 Logitech Circle Speaker Replacement: step 5, image 2 of 2
      • Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
      Ask FixBot
    6. Logitech Circle Speaker Replacement: step 6, image 1 of 2 Logitech Circle Speaker Replacement: step 6, image 2 of 2
      • Gently pull the ribbon cable loose from the lens/battery bundle.
      • While this is not an entirely necessary step, it helps to ensure the ribbon cable will not break during the rest of the replacement.
      Ask FixBot
    7. Logitech Circle Speaker Replacement: step 7, image 1 of 1
      • Locate the speaker attachment, and carefully remove the speaker plug from the lens.
      Ask FixBot
    8. Logitech Circle Speaker Replacement: step 8, image 1 of 1
      • Remove the speaker using a plastic opening tool. The battery is attached with glue, so use gentle prying motions to remove speaker.
      Ask FixBot
Emma Cochran
137 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 103
All Time: 1,068
