Up to 20% off select tools
Logitech Circle Ribbon Cable Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
99
All Time:
3,065
Comments: 6
6 guide comments.
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will allow you to remove and replace the ribbon inside of the Logitech Circle. This guide is a bit more involved, as there are several screws that need to be removed and you will need to puncture the base of the Logitech in order to remove the cable. Be sure to keep the screws organized for easier reconstruction.
    1. Logitech Circle Ribbon Cable Replacement, Ribbon Cable: step 1, image 1 of 2 Logitech Circle Ribbon Cable Replacement, Ribbon Cable: step 1, image 2 of 2
      • Wedge the plastic opening tool under the black circle lens and gently pry it off.
      • The lens is only attached with sticky tape and should remove relatively easily.
      Ask FixBot
    2. Logitech Circle Ribbon Cable Replacement: step 2, image 1 of 2 Logitech Circle Ribbon Cable Replacement: step 2, image 2 of 2
      • Remove the four 3mm Phillips #0 screws that hold down the first ring.
      Ask FixBot
    3. Logitech Circle Ribbon Cable Replacement: step 3, image 1 of 2 Logitech Circle Ribbon Cable Replacement: step 3, image 2 of 2
      • Remove the four 3mm Phillips #0 screws that hold down the second ring.
      Ask FixBot
    4. Logitech Circle Ribbon Cable Replacement: step 4, image 1 of 2 Logitech Circle Ribbon Cable Replacement: step 4, image 2 of 2
      • Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
      • The lens/battery bundle is attached to the base by a ribbon cable that can break, so be very careful handling the circle.
      Ask FixBot
    5. Logitech Circle Ribbon Cable Replacement: step 5, image 1 of 2 Logitech Circle Ribbon Cable Replacement: step 5, image 2 of 2
      • Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
      Ask FixBot
    6. Logitech Circle Ribbon Cable Replacement: step 6, image 1 of 2 Logitech Circle Ribbon Cable Replacement: step 6, image 2 of 2
      • Gently pull the ribbon cable loose from the lens/battery bundle.
      • While this is not an entirely necessary step, it helps to ensure the ribbon cable will not break during the rest of the replacement.
      Ask FixBot
    7. Logitech Circle Ribbon Cable Replacement: step 7, image 1 of 3 Logitech Circle Ribbon Cable Replacement: step 7, image 2 of 3 Logitech Circle Ribbon Cable Replacement: step 7, image 3 of 3
      • Once the old ribbon cable has been detached from the lens/battery bundle it's time to release the other side from the base.
      • Locate the screws holding the base together by feeling for the soft spots underneath the manufacturer's sticker. Punch through with your screwdriver and remove the three 3mm Phillips #0 screws.
      • The two pieces of the base can now be easily pulled apart.
      Ask FixBot
    8. Logitech Circle Ribbon Cable Replacement: step 8, image 1 of 2 Logitech Circle Ribbon Cable Replacement: step 8, image 2 of 2
      • Gently pull the ribbon cable loose from its connection to the base.
      Ask FixBot
    9. Logitech Circle Ribbon Cable Replacement: step 9, image 1 of 2 Logitech Circle Ribbon Cable Replacement: step 9, image 2 of 2
      • Slide the push pin holding the plastic connector/ribbon cable in place out on both sides.
      Ask FixBot
    10. Logitech Circle Ribbon Cable Replacement: step 10, image 1 of 1
      • Remove the black plastic connector and the two springs from the base of the device.
      Ask FixBot
    11. Logitech Circle Ribbon Cable Replacement: step 11, image 1 of 1
      • Reach inside the circle and pull the ribbon cable free from the device.
      Ask FixBot
Author
with
Haley Williams
112 Reputation
1 Guide authored
6 Guide Comments
where can I buy such a cable?
kersop@gmail.com
Nico Kersop - Reply Share
The cable I received from China is not the right one. Where do you buy the correct one?
Helen - Reply Share
Can you advise where to buy the correct cable?
Michele Ingratta - Reply Share
I have cable has beark off. I need that cable.
Where can I find
Alican Döşlü - Reply Share
i also need that cable
l_samin - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 99
All Time: 3,065
