Up to 20% off select tools
Logitech C920 Webcam Disassembly
Views: 75K
View statistics:
Past 24 Hours:
21
Past 7 Days:
166
Past 30 Days:
696
All Time:
75,202
Comments: 86
54 comments on steps, 32 guide comments.
Go to guide comments
Completed: 43
43 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
    1. Logitech C920 Webcam Disassembly, Logitech C920 Webcam Disassembly: step 1, image 1 of 2 Logitech C920 Webcam Disassembly, Logitech C920 Webcam Disassembly: step 1, image 2 of 2
      • On the bottom side of the webcam, remove the stickers from both sides
      Ask FixBot
    2. Logitech C920 Webcam Disassembly: step 2, image 1 of 1
      • Remove the four Phillips screws.
      • Press into the holes to unlock the side covers.
      Ask FixBot
    3. Logitech C920 Webcam Disassembly: step 3, image 1 of 2 Logitech C920 Webcam Disassembly: step 3, image 2 of 2
      • Once you’ve removed the side covers, unscrew all eight Phillips screws highlighted.
      Ask FixBot
    4. Logitech C920 Webcam Disassembly: step 4, image 1 of 3 Logitech C920 Webcam Disassembly: step 4, image 2 of 3 Logitech C920 Webcam Disassembly: step 4, image 3 of 3
      • Remove the lens's cover.
      • Remove the five Phillips screws of the metal bracket.
      • Remove the rubber pieces of both microphones (one on each side).
      Ask FixBot
    5. Logitech C920 Webcam Disassembly: step 5, image 1 of 1
      • Carefully remove the metal supports from the webcam's base.
      Ask FixBot
    6. Logitech C920 Webcam Disassembly: step 6, image 1 of 2 Logitech C920 Webcam Disassembly: step 6, image 2 of 2
      • Carefully remove the base of the plastic support. Loosen the three screws that secure the electronic circuit.
      Ask FixBot
    7. Logitech C920 Webcam Disassembly: step 7, image 1 of 1
      • Disconnect the USB cable connector.
      Ask FixBot
    8. Logitech C920 Webcam Disassembly: step 8, image 1 of 1
      • Remove the electronic circuit.
      Ask FixBot
    9. Logitech C920 Webcam Disassembly: step 9, image 1 of 2 Logitech C920 Webcam Disassembly: step 9, image 2 of 2
      • Release the clip that secures the cable holder. Pull this cable holder out of the camera.
      Ask FixBot
    10. Logitech C920 Webcam Disassembly: step 10, image 1 of 2 Logitech C920 Webcam Disassembly: step 10, image 2 of 2
      • Front and back images of the webcam's electronic circuit board.
      Ask FixBot
    11. Logitech C920 Webcam Disassembly: step 11, image 1 of 1
      • The problem was the broken cable on the back of the camera. I've cut the faulty part and redid the connections by soldering them and insulated them with heat shrink tubes.
      Ask FixBot
    12. Logitech C920 Webcam Disassembly: step 12, image 1 of 1
      • The repaired cable is reattached to the camera. Wrapped it with some masking tape. Camera tested: OK!
      • Assemble the webcam following the steps in a reverse order.
      Ask FixBot
43 other people completed this guide.
Special thanks to these translators:
pt en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Jose Gustavo Abreu Murta
5,212 Reputation
9 Guides authored
32 Guide Comments
Excellent! Helped me figure out how to get the base off to mount it to an ikea worklamp as a hacky boom.
Cory Elsmore - Reply Share
Can you post a guide or technique of the process?
Or share some photos? (On meta.ifixit.com)
Kind-hearted, spirited Man - Reply Share
Cory,
I did not understand your question.
This repair guide contains several photos.
Jose Gustavo Abreu Murta - Reply Share
thanks for an excellent guide . I am now more positive that it is something I can perform now. Many thanks
Graham Klaer - Reply Share
im having trouble releasing the 4 screws on step 3!!! the screw driver keeps slipping and i’ve tried a few and another webcam…
Dojo Mats - Sunny - Reply Share
Past 24 Hours: 21
Past 7 Days: 166
Past 30 Days: 696
All Time: 75,202
