Up to 20% off select tools
Logitech B100 Mouse - Disassembly
Views: 4.9K
View statistics:
Past 24 Hours:
10
Past 7 Days:
100
Past 30 Days:
420
All Time:
4,890
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
The Logitech B100 mouse is an simple and inexpensive mouse. Also the disassembly is very easy.
    1. Logitech B100 Mouse - Disassembly, Mouse: step 1, image 1 of 1
      • Remove one Phillips screw.
      • Very nice: You don't have to remove mouse feet to reach screws.
      Ask FixBot
    2. Logitech B100 Mouse - Disassembly: step 2, image 1 of 3 Logitech B100 Mouse - Disassembly: step 2, image 2 of 3 Logitech B100 Mouse - Disassembly: step 2, image 3 of 3
      • Open the gap with your fingernail or the flat end of a spudger.
      • Slide the upper part in direction of the mouse calbe. Use your other hand to hold the lower part of the mouse.
      • Remove the upper part and put it aside.
      Ask FixBot
    3. Logitech B100 Mouse - Disassembly: step 3, image 1 of 3 Logitech B100 Mouse - Disassembly: step 3, image 2 of 3 Logitech B100 Mouse - Disassembly: step 3, image 3 of 3
      • Lift the assembly of the mouse wheel.
      • You can see two springs.
      • Spring for haptical feedback while scrolling the mouse wheel.
      • Spring for reset the position after a mouse wheel click.
      Ask FixBot
    4. Logitech B100 Mouse - Disassembly: step 4, image 1 of 2 Logitech B100 Mouse - Disassembly: step 4, image 2 of 2
      • Pull out the USB cable from the bracket.
      • Optional: Unplug the connector from the board.
      Ask FixBot
    5. Logitech B100 Mouse - Disassembly: step 5, image 1 of 3 Logitech B100 Mouse - Disassembly: step 5, image 2 of 3 Logitech B100 Mouse - Disassembly: step 5, image 3 of 3
      • Lift the board in the front and pull it out in forward direction.
      Ask FixBot
    6. Logitech B100 Mouse - Disassembly: step 6, image 1 of 2 Logitech B100 Mouse - Disassembly: step 6, image 2 of 2
      • Reference pictures of the board.
      Ask FixBot
    7. Logitech B100 Mouse - Disassembly, Optional for cleaning: step 7, image 1 of 3 Logitech B100 Mouse - Disassembly, Optional for cleaning: step 7, image 2 of 3 Logitech B100 Mouse - Disassembly, Optional for cleaning: step 7, image 3 of 3
      • Find the four plastic clips. They hold the two upper parts together.
      • Release the two plastic clips at the back.
      • Release the two plastic clips in the middle.
      Ask FixBot
    8. Logitech B100 Mouse - Disassembly: step 8, image 1 of 2 Logitech B100 Mouse - Disassembly: step 8, image 2 of 2
      • Increase the already present gap.
      • Push both parts apart.
      Ask FixBot
    9. Logitech B100 Mouse - Disassembly: step 9, image 1 of 1
      • Overview of all parts.
      Ask FixBot
Reverse the steps to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
Xare is helping us fix the world! Want to contribute?
Start translating ›
Author
with
Xare
3,077 Reputation
10 Guides authored
1 Guide Comment
Thanks for the guide. The wheel of my B100 mouse is not working properly recently. When I follow the guide and take it apart, I realized the dirt on the wheel is blocking the laser sensor on the left. After cleaning the dirt with a toothbrush the problem is fully solved.
Thanks again for the guide, it really helps.
Alexander Chen - Reply Share
Past 24 Hours: 10
Past 7 Days: 100
Past 30 Days: 420
All Time: 4,890
