Logitech A20 X Lightspeed Battery Replacement
View statistics:
Past 24 Hours:
7
Past 7 Days:
25
Past 30 Days:
84
All Time:
417
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace a worn out or dead battery in your Logitech A20 X Lightspeed wireless headset.
The li-ion battery resides within the right ear cup.
It’s natural for batteries to lose capacity as they age. If your headset dies quickly and doesn't hold a charge, it may be time to replace the battery.
If possible, drain the headset's battery before you begin repairs. You'll hear an audio beep every 30 minutes when the battery's low.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Logitech A20 X Lightspeed Battery Replacement, Prepare the headset for disassembly: step 1, image 1 of 2 Logitech A20 X Lightspeed Battery Replacement, Prepare the headset for disassembly: step 1, image 2 of 2
      • Power off the headset and unplug all cables.
      Ask FixBot
    1. Logitech A20 X Lightspeed Battery Replacement, Remove the right ear pad: step 2, image 1 of 3 Logitech A20 X Lightspeed Battery Replacement, Remove the right ear pad: step 2, image 2 of 3 Logitech A20 X Lightspeed Battery Replacement, Remove the right ear pad: step 2, image 3 of 3
      • With one hand, firmly hold the right ear cup steady.
      • With your free hand, slowly pull the ear pad away from the cup until it slides completely off its plastic lip.
      • Remove the ear cup and set it aside for reassembly.
      Ask FixBot
    2. Logitech A20 X Lightspeed Battery Replacement, Reassembly tip: step 3, image 1 of 3 Logitech A20 X Lightspeed Battery Replacement, Reassembly tip: step 3, image 2 of 3 Logitech A20 X Lightspeed Battery Replacement, Reassembly tip: step 3, image 3 of 3
      • During reassembly, installing the ear pad can be tricky. Be patient and work slowly—it may take a couple tries. To put an ear pad onto its cup:
      • With one hand, firmly hold an ear cup steady.
      • With your free hand, place the pad over the top of the cup, so the fabric flap slips over the cup's plastic lip.
      • Thread the rest of the flap over the lip, working your way around the entire cup. Gently stretch the pad as necessary.
      • Check the entire perimeter of the cup to make sure the ear pad is fully on. If any of the fabric flap is sticking out, try to push it over the lip or remove the ear pad and try again.
      Ask FixBot
    3. Logitech A20 X Lightspeed Battery Replacement, Remove the right speaker housing screws: step 4, image 1 of 1
      • Use a Phillips screwdriver to remove the two 7.2 mm‑long screws securing the right speaker housing.
      Ask FixBot
    4. Logitech A20 X Lightspeed Battery Replacement, Move the speaker housing: step 5, image 1 of 3 Logitech A20 X Lightspeed Battery Replacement, Move the speaker housing: step 5, image 2 of 3 Logitech A20 X Lightspeed Battery Replacement, Move the speaker housing: step 5, image 3 of 3
      • Don't try to fully remove the speaker housing, as a delicate cable connects it to the ear cup.
      • Use your fingers to lift the bottom edge of the speaker housing.
      • Shift the speaker housing down as you lift it to free the top edge from the ear cup.
      Ask FixBot
    5. Logitech A20 X Lightspeed Battery Replacement: step 6, image 1 of 2 Logitech A20 X Lightspeed Battery Replacement: step 6, image 2 of 2
      • Gently remove the speaker housing and set it next to the ear cup, making sure the cable isn't strained.
      Ask FixBot
    6. Logitech A20 X Lightspeed Battery Replacement, Reassembly tip: step 7, image 1 of 3 Logitech A20 X Lightspeed Battery Replacement, Reassembly tip: step 7, image 2 of 3 Logitech A20 X Lightspeed Battery Replacement, Reassembly tip: step 7, image 3 of 3
      • During reassembly:
      • Align the top edge of the speaker housing with the two plastic tabs in the ear cup.
      • Once you've aligned the top edge, lay the speaker housing in place on top of the ear cup.
      Ask FixBot
    7. Logitech A20 X Lightspeed Battery Replacement, Disconnect the speaker: step 8, image 1 of 3 Logitech A20 X Lightspeed Battery Replacement, Disconnect the speaker: step 8, image 2 of 3 Logitech A20 X Lightspeed Battery Replacement, Disconnect the speaker: step 8, image 3 of 3
      • Use your fingernails to grip the edges of the speaker connector and slide it out of its socket.
      • You can also use a pair of angled tweezers, but be very careful not to puncture the battery.
      • If you're having trouble, try rocking the connector side-to-side to help loosen it.
      Ask FixBot
    8. Logitech A20 X Lightspeed Battery Replacement: step 9, image 1 of 2 Logitech A20 X Lightspeed Battery Replacement: step 9, image 2 of 2
      • Set the speaker housing aside for reassembly
      • To reconnect the speaker housing during assembly:
      • Align the connector (it connects in only one orientation) and use your finger to gently push it into its socket. You should feel a faint click when it's fully seated.
      Ask FixBot
    9. Logitech A20 X Lightspeed Battery Replacement, Disconnect the battery: step 10, image 1 of 3 Logitech A20 X Lightspeed Battery Replacement, Disconnect the battery: step 10, image 2 of 3 Logitech A20 X Lightspeed Battery Replacement, Disconnect the battery: step 10, image 3 of 3
      • Use your fingernails to grip the edges of the battery connector and slide it out of its socket.
      • You can also use a pair of angled tweezers, but be very careful not to puncture the battery or touch the three metal contacts on the connector.
      • During reassembly, align the connector (it connects in only one orientation) and use your finger to gently push it into its socket. You should feel a faint click when it's fully seated.
      Ask FixBot
    10. Logitech A20 X Lightspeed Battery Replacement, Remove the battery: step 11, image 1 of 3 Logitech A20 X Lightspeed Battery Replacement, Remove the battery: step 11, image 2 of 3 Logitech A20 X Lightspeed Battery Replacement, Remove the battery: step 11, image 3 of 3
      • The battery's adhered to the ear cup with an adhesive pad.
      • Slowly press an opening pick under the edge of the battery, where the wires come out.
      • Apply pressure until the battery loosens from the ear cup.
      • If the battery won't budge, apply a drop of high concentration (>90%) isopropyl alcohol under the battery, wait a minute, and try again.
      Ask FixBot
    11. Logitech A20 X Lightspeed Battery Replacement: step 12, image 1 of 2 Logitech A20 X Lightspeed Battery Replacement: step 12, image 2 of 2
      • Use your fingers to slowly peel the battery away from the ear cup.
      • Remove the battery.
      Ask FixBot
    12. Logitech A20 X Lightspeed Battery Replacement, Reassembly tip: step 13, image 1 of 3 Logitech A20 X Lightspeed Battery Replacement, Reassembly tip: step 13, image 2 of 3 Logitech A20 X Lightspeed Battery Replacement, Reassembly tip: step 13, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • To attach a new battery:
      • If your replacement battery comes with adhesive pre-installed, remove the liner.
      • If your replacement battery doesn't come with adhesive pre-installed, install strips of double-sided tape onto the battery.
      • Center the battery in its recess.
      • Use your fingers to firmly press the battery to secure it in place.
      Ask FixBot
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to an R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Arthur Shi
352,090 Reputation
937 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 25
Past 30 Days: 84
All Time: 417
