Introduction
The shell or case of the Little Tikes Tobi 2 Interactive Karaoke Machine serves as the outer protective cover of the device, shielding all the delicate internal components from potential damage caused by external sources. It acts as the first line of defense, ensuring that the circuitry, circuit board, screen, buttons, and other sensitive parts remain safe and intact. The shell is made of durable materials such as plastic, metal, or a combination of both, designed to withstand impacts, dust, moisture, and general wear and tear that may occur during daily use.
Before you begin this repair, make sure that your Little Tikes Tobi 2 Interactive Karaoke Machine is off and the batteries are removed.
Use a Phillips screwdriver to remove the single screw that is holding the cover to the battery compartment.
Use a spudger to carefully pry off the battery cover.
Use a Phillips screwdriver to remove four screws from the base of the device.
Remove the bottom of the karaoke machine.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
