Little Tikes Tobi 2 Interactive Karaoke Machine Button Board Replacement
    1. Little Tikes Tobi 2 Interactive Karaoke Machine Button Board Replacement, Battery: step 1, image 1 of 3 Little Tikes Tobi 2 Interactive Karaoke Machine Button Board Replacement, Battery: step 1, image 2 of 3 Little Tikes Tobi 2 Interactive Karaoke Machine Button Board Replacement, Battery: step 1, image 3 of 3
      • Use a Phillips screwdriver to remove the single screw that is holding the cover to the battery compartment.
      • If the screw doesn’t come out right away, use a spudger to gently lift the edge of the battery compartment in the recessed area while continuing to unscrew it with your other hand.
      • Use a spudger to carefully pry off the battery cover.
      Ask FixBot
    2. Little Tikes Tobi 2 Interactive Karaoke Machine Button Board Replacement: step 2, image 1 of 2 Little Tikes Tobi 2 Interactive Karaoke Machine Button Board Replacement: step 2, image 2 of 2
      • To easily pop out a battery, use your thumb to push the battery from the flat side down toward the coil and pull the battery outward.
      • Remove all four batteries.
      • Take a new AA alkaline battery and position it in the correct orientation. Insert the flat side of the battery facing the coil first, then press the raised side down. Ensure this second battery is oriented in the opposite direction to the first. Continue replacing the batteries in an alternating pattern.
      Ask FixBot
    1. Little Tikes Tobi 2 Interactive Karaoke Machine Button Board Replacement, Case: step 3, image 1 of 1
      • Use a Phillips screwdriver to remove four screws from the base of the device.
      • If the screws don't come out, you can gently lift them with the screwdriver tip or push them out from the other side once they're all loosened.
      • Remove the bottom of the karaoke machine.
      • Don't pull it apart roughly as it is attached to internal cables and they may be damaged in the process.
      Ask FixBot
    2. Little Tikes Tobi 2 Interactive Karaoke Machine Button Board Replacement: step 4, image 1 of 1
      • Use a Phillips screwdriver to remove the four screws from the interior of the white base.
      Ask FixBot
    3. Little Tikes Tobi 2 Interactive Karaoke Machine Button Board Replacement: step 5, image 1 of 2 Little Tikes Tobi 2 Interactive Karaoke Machine Button Board Replacement: step 5, image 2 of 2
      • Use a Phillips screwdriver to remove the four screws from the exterior black plastic part of the case.
      • Use a spudger to disassemble the case.
      Ask FixBot
    1. Little Tikes Tobi 2 Interactive Karaoke Machine Button Board Replacement, Button Board: step 6, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the four screws from the half-circle clear plastic covering the underside of the top of the device.
      Ask FixBot
    2. Little Tikes Tobi 2 Interactive Karaoke Machine Button Board Replacement: step 7, image 1 of 1
      • Remove the three Phillips #0 screws from the back of the circuit board.
      Ask FixBot
    3. Little Tikes Tobi 2 Interactive Karaoke Machine Button Board Replacement: step 8, image 1 of 1
      • Flip the button board over to access the solder points
      • Desolder the wires from the button board to remove it.
      • Be careful when soldering as the soldering iron gets extremely hot and can burn.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Isaiah Eagle
607 Reputation
5 Guides authored
CSU Los Angeles, Team 5-4, Kershman Fall 2024 Member of CSU Los Angeles, Team 5-4, Kershman Fall 2024
CSULA-KERSHMAN-F24S5G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 275
