Little Tikes Tobi 2 Interactive Karaoke Machine Battery Replacement
    1. Little Tikes Tobi 2 Interactive Karaoke Machine Battery Replacement, Battery: step 1, image 1 of 3 Little Tikes Tobi 2 Interactive Karaoke Machine Battery Replacement, Battery: step 1, image 2 of 3 Little Tikes Tobi 2 Interactive Karaoke Machine Battery Replacement, Battery: step 1, image 3 of 3
      • Use a Phillips screwdriver to remove the single screw that is holding the cover to the battery compartment.
      • If the screw doesn’t come out right away, use a spudger to gently lift the edge of the battery compartment in the recessed area while continuing to unscrew it with your other hand.
      • Use a spudger to carefully pry off the battery cover.
      Ask FixBot
    2. Little Tikes Tobi 2 Interactive Karaoke Machine Battery Replacement: step 2, image 1 of 2 Little Tikes Tobi 2 Interactive Karaoke Machine Battery Replacement: step 2, image 2 of 2
      • To easily pop out a battery, use your thumb to push the battery from the flat side down toward the coil and pull the battery outward.
      • Remove all four batteries.
      • Take a new AA alkaline battery and position it in the correct orientation. Insert the flat side of the battery facing the coil first, then press the raised side down. Ensure this second battery is oriented in the opposite direction to the first. Continue replacing the batteries in an alternating pattern.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Yuanwei Chen
185 Reputation
1 Guide authored
CSU Los Angeles, Team 5-4, Kershman Fall 2024 Member of CSU Los Angeles, Team 5-4, Kershman Fall 2024
CSULA-KERSHMAN-F24S5G4
4 Members
54 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 270
