Lite-On iHAS324 Chassis Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
99
All Time:
2,381
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Lite-On iHAS324 Chassis Replacement, Chassis: step 1, image 1 of 2 Lite-On iHAS324 Chassis Replacement, Chassis: step 1, image 2 of 2
      • Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
      • There may be resistance, do not be afraid to use force.
      • The tray should then pop open.
      • Pull out the tray so that it is fully extended.
      Ask FixBot
    2. Lite-On iHAS324 Chassis Replacement: step 2, image 1 of 3 Lite-On iHAS324 Chassis Replacement: step 2, image 2 of 3 Lite-On iHAS324 Chassis Replacement: step 2, image 3 of 3
      • Use a plastic opening tool to push the three tabs located on the right, left, and bottom side of the outer chassis to loosen the faceplate off.
      Ask FixBot
    3. Lite-On iHAS324 Chassis Replacement: step 3, image 1 of 1
      • Pull the faceplate off the chassis.
      • Do NOT pull the faceplate all the way off the disc tray, because doing so can cause damage to the faceplate.
      Ask FixBot
    4. Lite-On iHAS324 Chassis Replacement: step 4, image 1 of 1
      • Using the Phillips Head #2 screwdriver, unscrew the two 8.5 mm screws located on the bottom back of the chassis.
      Ask FixBot
    5. Lite-On iHAS324 Chassis Replacement: step 5, image 1 of 1
      • Remove the bottom plate by lifting it off the device.
      Ask FixBot
    6. Lite-On iHAS324 Chassis Replacement: step 6, image 1 of 1
      • Turn the device over.
      • Remove the top plate by pulling the sides and lifting the plate off.
      Ask FixBot
3 other people completed this guide.
Kayla Culpepper
726 Reputation
5 Guides authored
Baylor, Team 5-9, Williams Spring 2015 Member of Baylor, Team 5-9, Williams Spring 2015
BU-WILLIAMS-S15S5G9
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 99
All Time: 2,381
