Up to 20% off select tools
LisaTerminal with Linux/UNIX(Mac)
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
71
All Time:
1,247
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Very easy
Community-Contributed Guide
    1. LisaTerminal with Linux/UNIX(Mac), On Linux: step 1, image 1 of 1
      • In Terminal type: sudo apt-get install screen
      • sudo screen /dev/ttyUSB0 9600
      • Press ⌃A ⇧ : (at the same time). Once you see a : prompt at the bottom of the screen type
      • exec ::: /sbin/agetty -L -n 9600 ttyUSB0 vt100
      • Press return a few times on the Lisa keyboard and the login prompt should appear.
      Ask FixBot
    2. LisaTerminal with Linux/UNIX(Mac), On macOS: step 2, image 1 of 1
      • Type: ls /dev/cu.*
      • Copy the result that mentions USB
      • Then type the following replacing serial with the previous result: screen /dev/serial 9600
      • Press ⌃A ⇧:
      • When the : prompt appears type
      • exec ::: /usr/libexec/getty std.9600
      Ask FixBot
      • Open LisaTerminal and set the settings to baud rate 9600 and set serial port to A.
      • Plug the serial cable into serial port A.
      • In MacWorks Plus and Macintosh System 6, the application Mac240 supports graphics and is generally fantastic for this type of connection.
      • Mac240 can be acquired from Macintosh Garden.
      Ask FixBot
    3. LisaTerminal with Linux/UNIX(Mac), Uses: step 4, image 1 of 1
      • This was done so I could use mutt for email and w3m for web browsing
      • mpg123 is great for music if your connected computer has speakers.
      Ask FixBot
Finish Line
Author
with
LisaGuide
1,833 Reputation
11 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 71
All Time: 1,247
