Linsay Model F-7HD2CORE Screen Replacement
    1. Linsay Model F-7HD2CORE Screen Replacement, Screen: step 1, image 1 of 3 Linsay Model F-7HD2CORE Screen Replacement, Screen: step 1, image 2 of 3 Linsay Model F-7HD2CORE Screen Replacement, Screen: step 1, image 3 of 3
      • Insert your plastic opening tool in between the black and white portions of your device.
      • Gently pry the top screen from the base of the tablet.
      • Your tablet should now look like the third photo.
      Ask FixBot
    2. Linsay Model F-7HD2CORE Screen Replacement: step 2, image 1 of 2 Linsay Model F-7HD2CORE Screen Replacement: step 2, image 2 of 2
      • Peel the microphone from the back of the device.
      Ask FixBot
    3. Linsay Model F-7HD2CORE Screen Replacement: step 3, image 1 of 1
      • Remove the tape from the indicated copper strip.
      Ask FixBot
    4. Linsay Model F-7HD2CORE Screen Replacement: step 4, image 1 of 2 Linsay Model F-7HD2CORE Screen Replacement: step 4, image 2 of 2
      • Use your 00 phillips head screwdriver to remove the three 4mm phillips screws circled in red.
      Ask FixBot
    5. Linsay Model F-7HD2CORE Screen Replacement: step 5, image 1 of 1
      • Remove the soldered portion of the circuit board on the screen.
      • You will need a soldering kit to reattach this part.
      Ask FixBot
    6. Linsay Model F-7HD2CORE Screen Replacement: step 6, image 1 of 2 Linsay Model F-7HD2CORE Screen Replacement: step 6, image 2 of 2
      • Use the blunt end of the spudger to remove the circuit panel and battery from the glass screen portion of the device.
      • There will be several small hooks holding the screen onto the back panel.
      Ask FixBot
    7. Linsay Model F-7HD2CORE Screen Replacement: step 7, image 1 of 2 Linsay Model F-7HD2CORE Screen Replacement: step 7, image 2 of 2
      • Gently pull the two pieces of the tablet apart.
      • Your tablet should now look like image two.
      • You are now ready to attach your new screen!
      Ask FixBot
3 other people completed this guide.
Lindsay Byrnes
495 Reputation
2 Guides authored
Penn State, Team 1-5, Kaschak Winter 2015 Member of Penn State, Team 1-5, Kaschak Winter 2015
PSU-KASCHAK-W15S1G5
3 Members
24 Guides authored
1 Guide Comment
Excellent work!
Glen Lind - Reply Share
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 34
All Time: 1,693
