Linsay Model F-7HD2CORE Battery Replacement
    1. Linsay Model F-7HD2CORE Battery Replacement, Battery: step 1, image 1 of 3 Linsay Model F-7HD2CORE Battery Replacement, Battery: step 1, image 2 of 3 Linsay Model F-7HD2CORE Battery Replacement, Battery: step 1, image 3 of 3
      • Carefully insert your plastic opening tool in between the white and black sections of your device.
      • Gently pry the top screen portion from the base of the tablet.
      • Your tablet should now look like the third image.
      Ask FixBot
    2. Linsay Model F-7HD2CORE Battery Replacement: step 2, image 1 of 2 Linsay Model F-7HD2CORE Battery Replacement: step 2, image 2 of 2
      • To completely remove the base from the top of the tablet, peel the microphone from the back.
      Ask FixBot
    3. Linsay Model F-7HD2CORE Battery Replacement: step 3, image 1 of 2 Linsay Model F-7HD2CORE Battery Replacement: step 3, image 2 of 2
      • Remove the two pieces of tape holding the battery in place by gently peeling it off.
      Ask FixBot
    4. Linsay Model F-7HD2CORE Battery Replacement: step 4, image 1 of 1
      • Using the spudger, carefully peel the battery off of the tablet panel.
      • Tape of the back of the battery will be very strong, pull gently!
      • The metal exterior of the battery can be quite pliable. Use caution when removing the battery from the tablet.
      Ask FixBot
    5. Linsay Model F-7HD2CORE Battery Replacement: step 5, image 1 of 1
      • To remove the battery, completely desolder the wires connected to the circuit board.
      • To reattach the new battery, you must solder the wires back on.
      Ask FixBot
2 other people completed this guide.
Lindsay Byrnes
495 Reputation
2 Guides authored
Penn State, Team 1-5, Kaschak Winter 2015 Member of Penn State, Team 1-5, Kaschak Winter 2015
PSU-KASCHAK-W15S1G5
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 1,823
