Linksys WRT54GS v2 Rear Case Replacement
  1. Linksys WRT54GS v2 Rear Case Replacement, Front Case: step 1, image 1 of 1
    • Turn the router over so that all four of its feet are facing upwards.
    Ask FixBot
  2. Linksys WRT54GS v2 Rear Case Replacement: step 2, image 1 of 1
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
    Ask FixBot
  3. Linksys WRT54GS v2 Rear Case Replacement: step 3, image 1 of 1
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
    Ask FixBot
  4. Linksys WRT54GS v2 Rear Case Replacement: step 4, image 1 of 1
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
    Ask FixBot
  5. Linksys WRT54GS v2 Rear Case Replacement, Motherboard: step 5, image 1 of 1
    • Slide the board unit out and up.
    Ask FixBot
  6. Linksys WRT54GS v2 Rear Case Replacement: step 6, image 1 of 1
    • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
    • Slide the back cover out and away from the circuit board.
    Ask FixBot
  7. Linksys WRT54GS v2 Rear Case Replacement, Rear Case: step 7, image 1 of 1
    • Removing the router's rear case is the same as removing the motherboard, since the two parts are attached to each other.
    • Once you complete this step, your router will be completely disassembled.
    Ask FixBot
Allian Roman
276 Reputation
5 Guides authored
Cal Poly, Team 3-4, Regan Fall 2011 Member of Cal Poly, Team 3-4, Regan Fall 2011
CPSU-REGAN-F11S3G4
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 23
All Time: 1,802
