Linksys WRT54GS v2 Power Connector Replacement
  1. Linksys WRT54GS v2 Power Connector Replacement, Front Case: step 1, image 1 of 1
    • Turn the router over so that all four of its feet are facing upwards.
    Ask FixBot
  2. Linksys WRT54GS v2 Power Connector Replacement: step 2, image 1 of 1
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
    Ask FixBot
  3. Linksys WRT54GS v2 Power Connector Replacement: step 3, image 1 of 1
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
    Ask FixBot
  4. Linksys WRT54GS v2 Power Connector Replacement: step 4, image 1 of 1
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
    Ask FixBot
  5. Linksys WRT54GS v2 Power Connector Replacement, Motherboard: step 5, image 1 of 1
    • Slide the board unit out and up.
    Ask FixBot
  6. Linksys WRT54GS v2 Power Connector Replacement: step 6, image 1 of 1
    • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
    • Slide the back cover out and away from the circuit board.
    Ask FixBot
  7. Linksys WRT54GS v2 Power Connector Replacement, Power Connector: step 7, image 1 of 1
    • Turn the circuit board over.
    • Identify the solder connections on the board, marked in red.
    Ask FixBot
  8. Linksys WRT54GS v2 Power Connector Replacement: step 8, image 1 of 1
    • Desolder the connection by following iFixit's guide to repairing soldered connections: How To Solder and Desolder Connections.
    • Remove the Power Connector from the board.
    • Insert the replacement power port and resolder the connectors.
    Ask FixBot
Alex Do
51 Reputation
1 Guide authored
Cal Poly, Team 3-4, Regan Fall 2011 Member of Cal Poly, Team 3-4, Regan Fall 2011
CPSU-REGAN-F11S3G4
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 34
All Time: 2,215
