Linksys WRT54GS v2 Front Case Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
72
All Time:
1,604
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
In this guide you will remove the router's front case and begin to have access to the router's internal components.
Tools
    1. Linksys WRT54GS v2 Front Case Replacement, Front Case: step 1, image 1 of 1
      • Turn the router over so that all four of its feet are facing upwards.
      Ask FixBot
    2. Linksys WRT54GS v2 Front Case Replacement: step 2, image 1 of 1
      • Remove the rubber inserts inside the the two purple feet located on the router's front case.
      • This may be a challenge, so try the following two methods:
      • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
      • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
      Ask FixBot
    3. Linksys WRT54GS v2 Front Case Replacement: step 3, image 1 of 1
      • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
      Ask FixBot
    4. Linksys WRT54GS v2 Front Case Replacement: step 4, image 1 of 1
      • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
      Ask FixBot
Allian Roman
276 Reputation
5 Guides authored
Cal Poly, Team 3-4, Regan Fall 2011 Member of Cal Poly, Team 3-4, Regan Fall 2011
CPSU-REGAN-F11S3G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 72
All Time: 1,604
