Linksys WRT54G Motherboard Component Replacement
  1. Linksys WRT54G Motherboard Component Replacement, Antennas: step 1, image 1 of 1
    • Unfold the antennas straight away from the device.
    Ask FixBot
  2. Linksys WRT54G Motherboard Component Replacement: step 2, image 1 of 3 Linksys WRT54G Motherboard Component Replacement: step 2, image 2 of 3 Linksys WRT54G Motherboard Component Replacement: step 2, image 3 of 3
    • Remove the black caps from the antennas by pulling them away from the device.
    Ask FixBot
  3. Linksys WRT54G Motherboard Component Replacement: step 3, image 1 of 3 Linksys WRT54G Motherboard Component Replacement: step 3, image 2 of 3 Linksys WRT54G Motherboard Component Replacement: step 3, image 3 of 3
    • Unscrew each of the antennas from the wireless device.
    Ask FixBot
  4. Linksys WRT54G Motherboard Component Replacement, Casing: step 4, image 1 of 2 Linksys WRT54G Motherboard Component Replacement, Casing: step 4, image 2 of 2
    • Using a bit of force, remove the blue plastic case.
    Ask FixBot
  5. Linksys WRT54G Motherboard Component Replacement, Motherboard: step 5, image 1 of 2 Linksys WRT54G Motherboard Component Replacement, Motherboard: step 5, image 2 of 2
    • To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance.
    • Pull the top piece upwards and away from the bottom to remove.
    Ask FixBot
  6. Linksys WRT54G Motherboard Component Replacement: step 6, image 1 of 2 Linksys WRT54G Motherboard Component Replacement: step 6, image 2 of 2
    • Locate the 2 M2.5x6mm screws that attach the motherboard to the back case.
    • Remove the two screws from the motherboard as indicated with the Phillips head screwdriver.
    Ask FixBot
  7. Linksys WRT54G Motherboard Component Replacement: step 7, image 1 of 1
    • Once screws have been removed, slide the motherboard in the direction of its LED lights.
    • Lift motherboard up and away from the black lower casing.
    Ask FixBot
  8. Linksys WRT54G Motherboard Component Replacement, Motherboard Component: step 8, image 1 of 1
    • Obtain a desoldering wick (Desoldering Braid). Plug in soldering iron and allow to heat. For soldering information, refer to the iFixit soldering guide (How To Solder and Desolder Connections).
    • Make sure that the soldering iron is not resting on top of anything that would be damaged by the heat.
    Ask FixBot
  9. Linksys WRT54G Motherboard Component Replacement: step 9, image 1 of 2 Linksys WRT54G Motherboard Component Replacement: step 9, image 2 of 2
    • Identify the functional component which will be removed.
    • Turn the board over so that the pins holding the component in are exposed.
    Ask FixBot
  10. Linksys WRT54G Motherboard Component Replacement: step 10, image 1 of 1
    Ask FixBot
2 other people completed this guide.
Nicole C
114 Reputation
1 Guide authored
Cal Poly, Team 17-7, Regan Fall 2011 Member of Cal Poly, Team 17-7, Regan Fall 2011
CPSU-REGAN-F11S17G7
4 Members
4 Guides authored
1 Guide Comment
Se puede sustituir el puerto de entrada de Internet que es de red, por uno de telefono DSL?
Vladimir Velázquez - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 26
All Time: 4,274
