Linksys WAP 11 Motherboard Replacement
  1. Linksys WAP 11 Motherboard Replacement, Outer Case: step 1, image 1 of 1
    • Disconnect the power cables and ethernet from the device.
    • Unscrew the external plastic antennas. There is one antenna on each side of the device.
    Ask FixBot
  2. Linksys WAP 11 Motherboard Replacement: step 2, image 1 of 3 Linksys WAP 11 Motherboard Replacement: step 2, image 2 of 3 Linksys WAP 11 Motherboard Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • To open the Linksys WAP11, you will need a Phillips #1 screwdriver and a pair of metal tweezers.
    • Use the tweezers to remove the two rubber boots from the front two legs. Insert the tweezers in the hole of the boot and pull outwards.
    • This will reveal two small Phillips-head screws. Remove them.
    • Keep these two screws together.
    Ask FixBot
  3. Linksys WAP 11 Motherboard Replacement: step 3, image 1 of 2 Linksys WAP 11 Motherboard Replacement: step 3, image 2 of 2
    • Using two hands, pull on the top and bottom sections to separate the blue and the black pieces.
    • This requires significant amount of force.
    • The seal is located where the blue plastic meets the black plastic. This is where you will apply pressure.
    Ask FixBot
  4. Linksys WAP 11 Motherboard Replacement: step 4, image 1 of 1
    • After the face of the device has been removed, slide the base of the device off to reveal the motherboard and other internal components.
    • When removing the base, do not damage the wires that are attached to the device.
    Ask FixBot
  5. Linksys WAP 11 Motherboard Replacement: step 5, image 1 of 1
    • This is what the device looks like when it is fully opened.
    Ask FixBot
  6. Linksys WAP 11 Motherboard Replacement, Motherboard: step 6, image 1 of 2 Linksys WAP 11 Motherboard Replacement, Motherboard: step 6, image 2 of 2
    • At this point, remove the antenna leads as well.
    • Proceed to remove the remaining three phillips screws fastening the motherboard to the case.
    • Once the screws are removed, your motherboard will separate from the housing.
    • Keep these three screws together and separate from the outer case screws.
    Ask FixBot
Javier
46 Reputation
1 Guide authored
Cal Poly, Team 3-17, Regan Fall 2011 Member of Cal Poly, Team 3-17, Regan Fall 2011
CPSU-REGAN-F11S3G17
5 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 23
All Time: 1,919
