Linksys EA9200 Power Switch Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
82
All Time:
985
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
In the following guide you will be taking apart the outer casing to the Linksys EA9200, and desoldering the power switch from the circuit board. To complete this power switch removal you will need to have several tools as well as some practice desoldering. Both the tools needed as well as the steps to practicing desoldering are included in the guide.
Tools
    1. Linksys EA9200 Power Switch Replacement, Linksys EA9200 Disassembly: step 1, image 1 of 2 Linksys EA9200 Power Switch Replacement, Linksys EA9200 Disassembly: step 1, image 2 of 2
      • Remove the sticker on the bottom.
      • Remove the two screws holding the bottom plate in place. Use Phillips screwdriver tip #1 , the screw head-size is 5mm.
      Ask FixBot
    2. Linksys EA9200 Power Switch Replacement: step 2, image 1 of 2 Linksys EA9200 Power Switch Replacement: step 2, image 2 of 2
      • Remove the back sticker that has all the labels.
      • There are two screws to remove. They are 6mm in diameter, use phillips screw tip #1.
      Ask FixBot
    3. Linksys EA9200 Power Switch Replacement: step 3, image 1 of 3 Linksys EA9200 Power Switch Replacement: step 3, image 2 of 3 Linksys EA9200 Power Switch Replacement: step 3, image 3 of 3
      • Depress the 12 clips along the edge into the router. Use the nylon spudger as using a metal object could cause damage.
      Ask FixBot
    4. Linksys EA9200 Power Switch Replacement: step 4, image 1 of 3 Linksys EA9200 Power Switch Replacement: step 4, image 2 of 3 Linksys EA9200 Power Switch Replacement: step 4, image 3 of 3
      • Once you have one side open, keep a spudger wedged between both sides. This will help keep it open in case it tries to snap back together.
      • These clips are tough and may need some additional force.
      Ask FixBot
    5. Linksys EA9200 Power Switch Replacement: step 5, image 1 of 3 Linksys EA9200 Power Switch Replacement: step 5, image 2 of 3 Linksys EA9200 Power Switch Replacement: step 5, image 3 of 3
      • Lift the board and pull down, away from the antennas.
      Ask FixBot
    1. Linksys EA9200 Power Switch Replacement, Power Switch: step 6, image 1 of 3 Linksys EA9200 Power Switch Replacement, Power Switch: step 6, image 2 of 3 Linksys EA9200 Power Switch Replacement, Power Switch: step 6, image 3 of 3
      • Desolder the 7 pins for the power switch from the backside of the circuit board.
      • In order to remove this part you will need a soldering iron that is capable of reaching temperatures greater than 300 degrees Fahrenheit.
      • How To Solder and Desolder Connections is iFixit's official guide on how to use a soldering iron.
      Ask FixBot
Shane Davis
374 Reputation
3 Guides authored
USF Tampa, Team 9-1, Lacy Fall 2016 Member of USF Tampa, Team 9-1, Lacy Fall 2016
USFT-LACY-F16S9G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 82
All Time: 985
