Up to 20% off select tools
Lightahead DV328 Arrow Button Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
85
All Time:
823
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
We will be explaining how to replace the arrow button in the Lightahead DV328 camcorder.
There is only one caution that should be noted when working on this device. Opening the cover, which contains the motherboard underneath, should be done with caution. If it is lifted up too much, the piece will snap in half.
    1. Lightahead DV328 Arrow Button Replacement, Arrow Button: step 1, image 1 of 3 Lightahead DV328 Arrow Button Replacement, Arrow Button: step 1, image 2 of 3 Lightahead DV328 Arrow Button Replacement, Arrow Button: step 1, image 3 of 3
      • Use a spudger to remove the two screw covers.
      • Remove the two Phillips #0 screws.
      Ask FixBot
    2. Lightahead DV328 Arrow Button Replacement: step 2, image 1 of 3 Lightahead DV328 Arrow Button Replacement: step 2, image 2 of 3 Lightahead DV328 Arrow Button Replacement: step 2, image 3 of 3
      • Once you are able to lift the cover up, you will then be able to pry off the lens which will allow for the device to open more.
      • Take off the lens cover. Be careful not to pull the device open too much otherwise you will snap it in half since it is made of plastic.
      • Once you have this up, pull up the cover and you will now be able to work on the arrow key button
      Ask FixBot
    3. Lightahead DV328 Arrow Button Replacement: step 3, image 1 of 3 Lightahead DV328 Arrow Button Replacement: step 3, image 2 of 3 Lightahead DV328 Arrow Button Replacement: step 3, image 3 of 3
      • Lay the camcorder on its side. The arrow key button is now in full view.
      • There is a small green piece locking in the arrow key button. Once you remove that, the piece will be able to come out.
      • Gently push on the button and it will come out of the device. Replace as needed
      Ask FixBot
Author
with
Alexandra McMurray
355 Reputation
3 Guides authored
USF Tampa, Team 10-2, Remmell Spring 2016 Member of USF Tampa, Team 10-2, Remmell Spring 2016
USFT-REMMELL-S16S10G2
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 85
All Time: 823
