Lian Li PC-011 Hard Drive Replacement
Views: 9.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
40
Past 30 Days:
136
All Time:
9,363
Comments: 1
1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide is for first time builders or people that bought prebuilt computers in a Lian Li PC-011 case. This guide will walk you through how to install or replace a 3.5 hard drive in the case. It is not a very difficult task and it should only take you 30 minutes to complete.
Parts
Tools
    1. Lian Li PC-011 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
      • Power off the system using the button on the back of the computer.
      • Remove the power cord from the computer.
      Ask FixBot
    2. Lian Li PC-011 Hard Drive Replacement: step 2, image 1 of 3 Lian Li PC-011 Hard Drive Replacement: step 2, image 2 of 3 Lian Li PC-011 Hard Drive Replacement: step 2, image 3 of 3
      • Remove two thumb screws from the back of the case.
      • Slide the top panel backwards.
      Ask FixBot
    3. Lian Li PC-011 Hard Drive Replacement: step 3, image 1 of 3 Lian Li PC-011 Hard Drive Replacement: step 3, image 2 of 3 Lian Li PC-011 Hard Drive Replacement: step 3, image 3 of 3
      • Remove the remainder of the panels by pulling upwards on them.
      Ask FixBot
    4. Lian Li PC-011 Hard Drive Replacement: step 4, image 1 of 1
      • Remove the two 3 mm Phillips #2 screws from the wire cover.
      Ask FixBot
    5. Lian Li PC-011 Hard Drive Replacement: step 5, image 1 of 1
      • Unplug the two cables from the hard drive.
      Ask FixBot
    6. Lian Li PC-011 Hard Drive Replacement: step 6, image 1 of 2 Lian Li PC-011 Hard Drive Replacement: step 6, image 2 of 2
      • Push together the bottom and top tabs and pull the hard drive tray out of the case.
      Ask FixBot
    7. Lian Li PC-011 Hard Drive Replacement: step 7, image 1 of 1
      • Remove four #2 Phillips screws from the hard drive case in a cross pattern.
      Ask FixBot
    8. Lian Li PC-011 Hard Drive Replacement: step 8, image 1 of 1
      • Replace the old hard drive with the new hard drive.
      Ask FixBot
7 other people completed this guide.
Suhaib Rahman
470 Reputation
2 Guides authored
1 Guide Comment
Il ni à pas de languette chez moi et sa veut pas sortir
Antho - Reply Share
Past 24 Hours: 4
Past 7 Days: 40
Past 30 Days: 136
All Time: 9,363
