Up to 20% off select tools
Lexmark MX611de Maintenance Kit Replacement
Views: 6.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
39
Past 30 Days:
143
All Time:
6,416
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
    1. Lexmark MX611de Maintenance Kit Replacement, Right Cover Removal: step 1, image 1 of 2 Lexmark MX611de Maintenance Kit Replacement, Right Cover Removal: step 1, image 2 of 2
      • Remove the paper tray
      • Remove the screw securing the right cover to the front of the printer frame.
      • Open the memory access cover that is attached to the right cover
      • Remove the two screws securing the right cover to the RIP shield.
      • Slightly lift the printer, slide the right cover forward, and pull it out and away from the printer
      Ask FixBot
      • Remove the screw securing the left cover to the front of the printer frame.
      • Release the Two tabs on the bottom of the cover.
      • Pull the cover forward, and remove it from the printer.
      Ask FixBot
      • Open rear door.
      • Pull the exit door upward to release the hinges, and remove.
      • Remove the two screws securing the rear cover.
      • Remove the cover.
      Ask FixBot
      • Remove the three screws from the Left Mounting Bracket
      • Two different ways to the next step, dependent on experience and/or confidence.
      • Move the the Mounting Bracket over while extending the Stapler Cable out of the way, The Stapler cable does not have to disconnected.
      • Remove the Stapler Cable and Mounting bracket from the printer frame while feeding the cable through the redrive unit and printer frame.
      • Using a pair of pliers, squeeze the nylon mounts to dislodge the stapler connector, and remove the cable.
      • Remove the three screws from the Right mounting bracket.
      Ask FixBot
      • Remove the Two screws, and then disconnect the reverse solenoid.
      • Do not disconnect the reverse solenoid cable from the controller board.
      • Remove the Six screws securing the redrive assembly.
      Ask FixBot
      • Disconnect the cable JEXIT1 from the controller board.
      • Disconnect the Two cables.
      • Remove the Two screws securing the fuser.
      Ask FixBot
Author
with
alarson118
553 Reputation
3 Guides authored
Tech-zone Member of Tech-zone
Business
2 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 39
Past 30 Days: 143
All Time: 6,416
