Student In Progress
This guide is being worked on by hardworking students.
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Tweezers4.9
Introduction
Go to step 1 ↓The scanner unit allows users to scan copies.
Hold the button down with the flat end away from the printer. When you hear a click, the duplex unit can be removed from the printer.
Unscrew the two size #6 (5-mm head) Phillips 1-mm screws that connect the two cylindrical extensions from the top portion of the scanner unit to the printer.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 other people completed this guide.
