Lexmark Intuition S505 Ink Cartridges Replacement
    1. Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: step 1, image 1 of 2 Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: step 1, image 2 of 2
      • Lift the scanning unit, exposing the print head.
      Ask FixBot
    2. Lexmark Intuition S505 Ink Cartridges Replacement: step 2, image 1 of 1
      • Locate the frame around the ink cartridges. Press the button located at the front of the cartridge frame.
      Ask FixBot
    3. Lexmark Intuition S505 Ink Cartridges Replacement: step 3, image 1 of 1
      • Lift the frame to expose the ink cartridges.
      Ask FixBot
    4. Lexmark Intuition S505 Ink Cartridges Replacement: step 4, image 1 of 1
      • Push the button located above the designated ink cartridge until it pops out.
      Ask FixBot
    5. Lexmark Intuition S505 Ink Cartridges Replacement: step 5, image 1 of 1
      • Pull the cartridge out, and place the new ink cartridge back into the slot. Push until you hear a click.
      Ask FixBot
    6. Lexmark Intuition S505 Ink Cartridges Replacement: step 6, image 1 of 2 Lexmark Intuition S505 Ink Cartridges Replacement: step 6, image 2 of 2
      • Close the scanner unit.
      Ask FixBot
Once your ink cartridges are in place, your printer should now print high-quality documents.
3 other people completed this guide.
Omar
132 Reputation
2 Guides authored
Cal Poly, Team 18-38, Regan Winter 2013 Member of Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Members
48 Guides authored
3 Guide Comments
Hello there, thanks for your demonstration. In case that the cartridges are not genuine (not a lexmark brand), will the printer will be able to print?
I own this model. Thanks in advance!
Dimitri Sideris - Reply Share
Merci beaucoup pour tout
Bouzebiba - Reply Share
Merci beaucoup pour votre compréhension et bonne journée également bisous 😚
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 31
All Time: 3,818
