Lexibook Junior Tablet Headphone Jack Replacement
    1. Lexibook Junior Tablet Headphone Jack Replacement, Battery: step 1, image 1 of 1
      • Make sure your device is powered off before replacement to prevent electric shock.
      • With the device screen face down, use the metal spudger to remove the small rubber circles on all four corners of the device. The screws should now be revealed.
      • Using the metal spudger, pry open the small, long rubber rectangle on the back of the device to reveal more screws.
      Ask FixBot
    2. Lexibook Junior Tablet Headphone Jack Replacement: step 2, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the four 6.8mm screws from the four corners of the device.
      • Using the same screwdriver, remove the three screws that were behind the rubber rectangle. These screws do not come out of the device.
      • Use the plastic opening tool to gently pry open the back panel of the tablet.
      Ask FixBot
    3. Lexibook Junior Tablet Headphone Jack Replacement: step 3, image 1 of 1
      • Use the nylon spudger to gently pry under the battery to remove it.
      • Make sure you do not damage the battery or metal plate in this process and only use a nylon spudger. Be patient and work slowly for the best results.
      Ask FixBot
    4. Lexibook Junior Tablet Headphone Jack Replacement: step 4, image 1 of 1
      • Use a soldering iron to remove the battery from the motherboard safely.
      • For advice on how to solder, check out iFixit's Soldering Guide.
      Ask FixBot
    1. Lexibook Junior Tablet Headphone Jack Replacement, Motherboard: step 5, image 1 of 2 Lexibook Junior Tablet Headphone Jack Replacement, Motherboard: step 5, image 2 of 2
      • Using the plastic opening tool, gently push the two small, black and white switches out in the direction of the ribbon wires.
      • Slowly pull the ribbon wire out of the switch to free it.
      Ask FixBot
    2. Lexibook Junior Tablet Headphone Jack Replacement: step 6, image 1 of 1
      • Push the larger black and white strip leading to a ribbon wire upward using the plastic opening tool.
      • Carefully pull the ribbon wire out of the switch
      Ask FixBot
    3. Lexibook Junior Tablet Headphone Jack Replacement: step 7, image 1 of 3 Lexibook Junior Tablet Headphone Jack Replacement: step 7, image 2 of 3 Lexibook Junior Tablet Headphone Jack Replacement: step 7, image 3 of 3
      • Unscrew the five 4 mm screws around the perimeter of the motherboard using the ph00 size phillips head screwdriver.
      Ask FixBot
    4. Lexibook Junior Tablet Headphone Jack Replacement: step 8, image 1 of 2 Lexibook Junior Tablet Headphone Jack Replacement: step 8, image 2 of 2
      • Remove the button board by unscrewing two more 4 mm screws and one 6.5 mm screw
      Ask FixBot
    5. Lexibook Junior Tablet Headphone Jack Replacement: step 9, image 1 of 1
      • Solder off connections from the wire connecting the motherboard to the speaker.
      • For how to solder, check out iFixit's Soldering Guide.
      Ask FixBot
    1. Lexibook Junior Tablet Headphone Jack Replacement, Headphone Jack: step 10, image 1 of 1
      • Peel back the yellow film on top of the headphone jack.
      Ask FixBot
    2. Lexibook Junior Tablet Headphone Jack Replacement: step 11, image 1 of 1
      Ask FixBot
Rachel Klesius
645 Reputation
6 Guides authored
USF Tampa, Team 17-3, Blackwell Fall 2016 Member of USF Tampa, Team 17-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 60
All Time: 558
