LexiBook Tablet One Speaker Replacement
    1. LexiBook Tablet One Speaker Replacement, Speaker: step 1, image 1 of 3 LexiBook Tablet One Speaker Replacement, Speaker: step 1, image 2 of 3 LexiBook Tablet One Speaker Replacement, Speaker: step 1, image 3 of 3
      • Insert the blue plastic opening tool where the case has a seam. Move side to side until you hear a clip pop. Move around the edge of the case until all clips are separated. The clips are 1.5 in. apart within the case.
      Ask FixBot
    2. LexiBook Tablet One Speaker Replacement: step 2, image 1 of 2 LexiBook Tablet One Speaker Replacement: step 2, image 2 of 2
      • After successfully separating the casing insert a plastic spudger between the case and the speaker. Carefully pry the speaker out. Once the speaker is removed set the back casing aside.
      Ask FixBot
    3. LexiBook Tablet One Speaker Replacement: step 3, image 1 of 1
      • Using a soldering gun, apply heat where the speaker wires meet the motherboard. Heat the solder around both the black and red wires until they easily slide away.
      • Be careful not to heat the motherboard too long so to avoid damaging other components. Also, care to avoid liquefying the solder on any near by components.
      • How to Solder is IFixIt's official guide to use a soldering gun.
      Ask FixBot
Jordan
650 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 22
All Time: 438
