Lew's Mach Crush Speed Spool Disassembly
Featured Document
Preview of the first page of this document
Reel Manual
Log in to view the full document
Log In
      • Refer to the featured document for specific part names and exploded view. Determine whether you have the right-handed or left-handed reel.
      Ask FixBot
    1. Lew's Mach Crush Speed Spool Disassembly, Remove Left-Side Cover: step 2, image 1 of 2 Lew's Mach Crush Speed Spool Disassembly, Remove Left-Side Cover: step 2, image 2 of 2
      • Slide switch to 'open' on left side of reel to remove left cover.
      Ask FixBot
    2. Lew's Mach Crush Speed Spool Disassembly, Spool Assembly: step 3, image 1 of 1
      • Remove the palm-side cover, then spool assembly from center frame of reel.
      Ask FixBot
    3. Lew's Mach Crush Speed Spool Disassembly, Lube-Port Screw: step 4, image 1 of 1
      • Remove lube-port screw using small Phillips screwdriver.
      Ask FixBot
    4. Lew's Mach Crush Speed Spool Disassembly, Lube-Port Cover: step 5, image 1 of 1
      • Remove cover off of lube-port.
      Ask FixBot
    5. Lew's Mach Crush Speed Spool Disassembly, Handle Screw: step 6, image 1 of 1
      • Remove screw and handle nut from reel.
      Ask FixBot
    6. Lew's Mach Crush Speed Spool Disassembly, Removal of Handle: step 7, image 1 of 1
      • Remove handle and handle nut retainer.
      Ask FixBot
    7. Lew's Mach Crush Speed Spool Disassembly, Drag-Dial: step 8, image 1 of 1
      • Unscrew star-drag until it is loose, remove it and the handle washer from the shaft.
      • Note: You may have to hold the reels gears in place in order to unscrew the drag, as it will try to spin the gears.
      Ask FixBot
    8. Lew's Mach Crush Speed Spool Disassembly, Exterior Right-Cover Screws: step 9, image 1 of 1
      • Remove three spool cover screws from reel.
      Ask FixBot
    9. Lew's Mach Crush Speed Spool Disassembly, Cap: step 10, image 1 of 1
      • Remove cast control cap.
      Ask FixBot
    10. Lew's Mach Crush Speed Spool Disassembly, Removal of Right-Cover: step 11, image 1 of 1
      • Pry 2 drag spring washers, and 1 click holder washer off to finish removing side cover.
      Ask FixBot
    11. Lew's Mach Crush Speed Spool Disassembly, Removal of Pinion: step 12, image 1 of 1
      • Remove the pinion yoke and 2 pinion yoke springs
      Ask FixBot
    12. Lew's Mach Crush Speed Spool Disassembly, Removal of Main Gear: step 13, image 1 of 1
      • Remove drive gear and accompanying drag and ratchet washers.
      Ask FixBot
    13. Lew's Mach Crush Speed Spool Disassembly, Apply Oil: step 14, image 1 of 1
      • Apply oil to main gear if desired.
      Ask FixBot
    14. Lew's Mach Crush Speed Spool Disassembly, Make any necessary changes: step 15, image 1 of 1
      • At this point, you have disassembled the reel enough to where you can clean parts, remove dust and debris , or replace individual parts
      Ask FixBot
2 other people completed this guide.
Attached Documents
Rebecca Welch
250 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 47
All Time: 1,176
