Levoit Vital 100 HEPA Filter Replacement
    1. Levoit Vital 100 HEPA Filter Replacement, Filter: step 1, image 1 of 2 Levoit Vital 100 HEPA Filter Replacement, Filter: step 1, image 2 of 2
      • Unplug the air purifier and remove the cover by pulling the side handle away from machine.
      Ask FixBot
    2. Levoit Vital 100 HEPA Filter Replacement: step 2, image 1 of 1
      • Remove the old air filter by pulling the looped, white tab towards yourself.
      • This comes out without resistance and there are no hooked attachments.
      Ask FixBot
    3. Levoit Vital 100 HEPA Filter Replacement: step 3, image 1 of 1
      • Clean out any remaining dust and hair inside purifier using a vacuum or towel.
      Ask FixBot
    4. Levoit Vital 100 HEPA Filter Replacement: step 4, image 1 of 1
      • Unwrap the new filter and place it inside the air purifier with the tabs at the top and facing outward.
      • The filter should fit in snugly as there are no attachments surrounding the fitting.
      Ask FixBot
    5. Levoit Vital 100 HEPA Filter Replacement: step 5, image 1 of 2 Levoit Vital 100 HEPA Filter Replacement: step 5, image 2 of 2
      • Make sure air purifier cover is fitted properly by sinking the two legs into the holes shown at the arrows in photo one and then replacing the filter cover on the front by simply pushing it forward.
      • The air purifier will not power on unless the filter cover is replaced correctly.
      Ask FixBot
    6. Levoit Vital 100 HEPA Filter Replacement: step 6, image 1 of 1
      • After plugging the air purifier back in, reset the Check Filter Indicator by pressing the filter icon at the top and holding it for 3 seconds.
      Ask FixBot
Enjoy the fresh air!
Cody B
133 Reputation
1 Guide authored
1 Guide Comment
Thank you I really appreciate it. I got mine for 20 bucks at the thrift store and I was kind of confused if it was vent side or the fuzzy side.
Rose Wolfgang - Reply Share
Past 24 Hours: 7
Past 7 Days: 34
Past 30 Days: 204
All Time: 4,155
