Levoit LV-H132 Springs Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
63
All Time:
542
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Difficult
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
If the touch mechanism on your Levoit LV-H132 device is not working when it's switched on, the touch button springs might be damaged due to exposure to extreme temperatures, humidity, or corrosive chemicals.
Tools
    1. Levoit LV-H132 Springs Replacement, Springs: step 1, image 1 of 2 Levoit LV-H132 Springs Replacement, Springs: step 1, image 2 of 2
      • Pry off the plastic top using a metal spudger.
      Ask FixBot
    2. Levoit LV-H132 Springs Replacement: step 2, image 1 of 2 Levoit LV-H132 Springs Replacement: step 2, image 2 of 2
      • Remove the three 1.2 mm screws with a Phillips #1 screwdriver.
      Ask FixBot
    3. Levoit LV-H132 Springs Replacement: step 3, image 1 of 2 Levoit LV-H132 Springs Replacement: step 3, image 2 of 2
      • Disconnect the top half from the bottom.
      Ask FixBot
    4. Levoit LV-H132 Springs Replacement: step 4, image 1 of 3 Levoit LV-H132 Springs Replacement: step 4, image 2 of 3 Levoit LV-H132 Springs Replacement: step 4, image 3 of 3
      • Disconnect the circuit board cable.
      Ask FixBot
    5. Levoit LV-H132 Springs Replacement: step 5, image 1 of 2 Levoit LV-H132 Springs Replacement: step 5, image 2 of 2
      • Remove the two 5 mm screws with a Phillips #1 screwdriver.
      Ask FixBot
    6. Levoit LV-H132 Springs Replacement: step 6, image 1 of 1
      • Desolder the joints holding the springs.
      • Slide out the faulty springs.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 63
All Time: 542
