Levoit LV-H132 Motherboard Replacement
  1. Levoit LV-H132 Motherboard Replacement, Motherboard: step 1, image 1 of 2 Levoit LV-H132 Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Pry off the plastic top using a metal spudger.
    Ask FixBot
  2. Levoit LV-H132 Motherboard Replacement: step 2, image 1 of 2 Levoit LV-H132 Motherboard Replacement: step 2, image 2 of 2
    • Remove the three 1.2 mm screws with a Phillips #1 screwdriver.
    Ask FixBot
  3. Levoit LV-H132 Motherboard Replacement: step 3, image 1 of 2 Levoit LV-H132 Motherboard Replacement: step 3, image 2 of 2
    • Disconnect the top half from the bottom.
    Ask FixBot
  4. Levoit LV-H132 Motherboard Replacement: step 4, image 1 of 3 Levoit LV-H132 Motherboard Replacement: step 4, image 2 of 3 Levoit LV-H132 Motherboard Replacement: step 4, image 3 of 3
    • Disconnect the circuit board cables (one cable on each side).
    Ask FixBot
  5. Levoit LV-H132 Motherboard Replacement: step 5, image 1 of 2 Levoit LV-H132 Motherboard Replacement: step 5, image 2 of 2
    • Remove the black plastic piece.
    Ask FixBot
  6. Levoit LV-H132 Motherboard Replacement: step 6, image 1 of 2 Levoit LV-H132 Motherboard Replacement: step 6, image 2 of 2
    • Remove the two 5 mm screws that hold the motherboard vertically with a Phillips #1 screwdriver.
    Ask FixBot
  7. Levoit LV-H132 Motherboard Replacement: step 7, image 1 of 3 Levoit LV-H132 Motherboard Replacement: step 7, image 2 of 3 Levoit LV-H132 Motherboard Replacement: step 7, image 3 of 3
    • Remove four 5 mm screws from the motherboard cover with a Phillips #1 screwdriver.
    Ask FixBot
  8. Levoit LV-H132 Motherboard Replacement: step 8, image 1 of 2 Levoit LV-H132 Motherboard Replacement: step 8, image 2 of 2
    • Remove two 6 mm screws that hold the motherboard in place with a Phillips #1 screwdriver.
    Ask FixBot
2 other people completed this guide.
1 Guide Comment
Where do you get the motherboard replacement from and what kind?
Sarah S - Reply Share
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 59
All Time: 1,048
