Up to 20% off select tools
Levoit LV-H132 Filter Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
86
All Time:
973
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Does your Levoit LV-H132 have increased noise when it's switched on, have decreased airflow, have unusual odors, or a visibly clogged filter?  If so, use this guide to replace the filter. This repair is necessary so that the air filters are functioning as intended. There are no required tools to access or change the filter. Before starting, make sure the device is unplugged. By the end of this guide your device will work better.
    1. Levoit LV-H132 Filter Replacement, Filter: step 1, image 1 of 2 Levoit LV-H132 Filter Replacement, Filter: step 1, image 2 of 2
      • Orient your air purifier so that the control panel faces the bottom and the filter cover faces towards you.
      • Rotate the filter cover counterclockwise to separate the filter cover from the unit.
      Ask FixBot
    2. Levoit LV-H132 Filter Replacement: step 2, image 1 of 2 Levoit LV-H132 Filter Replacement: step 2, image 2 of 2
      • Grab the black sheet of mesh and set to the side.
      Ask FixBot
    3. Levoit LV-H132 Filter Replacement: step 3, image 1 of 2 Levoit LV-H132 Filter Replacement: step 3, image 2 of 2
      • By grabbing the two white tabs on each side, pull the tab upwards to remove the filter.
      Ask FixBot
2 other people completed this guide.
Author
with
Darryl Francis
407 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 86
All Time: 973
