Levoit LV-H132 Cord Replacement
  1. Levoit LV-H132 Cord Replacement, Cord: step 1, image 1 of 2 Levoit LV-H132 Cord Replacement, Cord: step 1, image 2 of 2
    • Pry off the plastic top using a metal spudger.
    Ask FixBot
  2. Levoit LV-H132 Cord Replacement: step 2, image 1 of 2 Levoit LV-H132 Cord Replacement: step 2, image 2 of 2
    • Remove the three 1.2 mm screws with a Phillips #1 screwdriver.
    Ask FixBot
  3. Levoit LV-H132 Cord Replacement: step 3, image 1 of 2 Levoit LV-H132 Cord Replacement: step 3, image 2 of 2
    • Disconnect the top half from the bottom.
    Ask FixBot
  4. Levoit LV-H132 Cord Replacement: step 4, image 1 of 3 Levoit LV-H132 Cord Replacement: step 4, image 2 of 3 Levoit LV-H132 Cord Replacement: step 4, image 3 of 3
    • Disconnect the circuit board cable.
    Ask FixBot
  5. Levoit LV-H132 Cord Replacement: step 5, image 1 of 2 Levoit LV-H132 Cord Replacement: step 5, image 2 of 2
    • Use a heat gun to heat up the heat-shrink tubing wraps.
    • Disconnect the damaged cable from the wires that are connected to the motherboard.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 41
All Time: 902
