Up to 20% off select tools
Levoit Core 300-RAC Power Cord Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
28
Past 30 Days:
164
All Time:
3,862
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
The Levoit Core 300-RAC receives electricity from a power cord, providing the energy needed to power on the device. If the power cord is severed, frayed, or damaged in any way, it could be dangerous or even impossible to operate your air purifier. The factory cord is 1.8 meters (about 6 feet) long and uses a Type A American plug. When looking for a replacement, ensure it's rated for 100-240V and 50/60Hz. Follow this guide to learn how to replace your existing power cord.
Before you begin, turn off your device and unplug it from the outlet.
    1. Levoit Core 300-RAC Power Cord Replacement, Air Filter: step 1, image 1 of 2 Levoit Core 300-RAC Power Cord Replacement, Air Filter: step 1, image 2 of 2
      • Make sure your device is turned off and unplugged for safety.
      • Turn the Levoit Core 300-RAC over so the bottom is facing up.
      Ask FixBot
    2. Levoit Core 300-RAC Power Cord Replacement: step 2, image 1 of 3 Levoit Core 300-RAC Power Cord Replacement: step 2, image 2 of 3 Levoit Core 300-RAC Power Cord Replacement: step 2, image 3 of 3
      • Turn the bottom cover counterclockwise and lift it off to remove it.
      • The cover does not "snap" on or off when turned.
      Ask FixBot
    3. Levoit Core 300-RAC Power Cord Replacement: step 3, image 1 of 3 Levoit Core 300-RAC Power Cord Replacement: step 3, image 2 of 3 Levoit Core 300-RAC Power Cord Replacement: step 3, image 3 of 3
      • Lift the filter straight up and out of the device.
      Ask FixBot
    1. Levoit Core 300-RAC Power Cord Replacement, Power Cord: step 4, image 1 of 3 Levoit Core 300-RAC Power Cord Replacement, Power Cord: step 4, image 2 of 3 Levoit Core 300-RAC Power Cord Replacement, Power Cord: step 4, image 3 of 3
      • Use a Phillips #2 screwdriver to remove the four screws that go through the four white tabs inside the device
      • Set the screws aside in a safe place.
      Ask FixBot
    2. Levoit Core 300-RAC Power Cord Replacement: step 5, image 1 of 3 Levoit Core 300-RAC Power Cord Replacement: step 5, image 2 of 3 Levoit Core 300-RAC Power Cord Replacement: step 5, image 3 of 3
      • Use a metal spudger to gently pry between the four white tabs and the white housing and release the outer housing.
      • Gently pull up on the outer housing to prevent the clips from resetting.
      Ask FixBot
    3. Levoit Core 300-RAC Power Cord Replacement: step 6, image 1 of 2 Levoit Core 300-RAC Power Cord Replacement: step 6, image 2 of 2
      • Remove the white outer housing and set it to the side.
      • The power cord is fed through a hole in the side of this housing, so it will need to be right next to the rest of the device.
      Ask FixBot
    4. Levoit Core 300-RAC Power Cord Replacement: step 7, image 1 of 3 Levoit Core 300-RAC Power Cord Replacement: step 7, image 2 of 3 Levoit Core 300-RAC Power Cord Replacement: step 7, image 3 of 3
      • Grab the cable channel by its base, squeeze, and pull up at the same time to remove it.
      Ask FixBot
    5. Levoit Core 300-RAC Power Cord Replacement: step 8, image 1 of 2 Levoit Core 300-RAC Power Cord Replacement: step 8, image 2 of 2
      • Remove the four Phillips #2 screws securing the gray face plate.
      Ask FixBot
    6. Levoit Core 300-RAC Power Cord Replacement: step 9, image 1 of 3 Levoit Core 300-RAC Power Cord Replacement: step 9, image 2 of 3 Levoit Core 300-RAC Power Cord Replacement: step 9, image 3 of 3
      • Insert a Jimmy or spudger between the white tab and the gray faceplate body to release the faceplate.
      • Lift it out.
      Ask FixBot
    7. Levoit Core 300-RAC Power Cord Replacement: step 10, image 1 of 1
      • Use wire cutters to carefully cut off the crimped power cord connections and remove the white power cord.
      • Cut as close to the connection as possible to leave as much of the internal wires as possible.
      • Cut your new power cable to length and replace the old one. You can splice the new cable on using a soldering iron, heat shrink tubing, and a heat gun. Alternatively, you can use twist-on wire nuts to make a secure connection. For more information on soldering, take a look at How to Solder and Desolder Connectors, and How to Use Heat Shrink Tubing.
      Ask FixBot
2 other people completed this guide.
Author
with
David Kamp
618 Reputation
3 Guides authored
UMass Dartmouth, Team 1-6, Petersen Fall 2023 Member of UMass Dartmouth, Team 1-6, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G6
5 Members
72 Guides authored
2 Guide Comments
You're a lifesaver, thank you! My rabbit managed to reach the cable for mine and chewed it up, my allergies have been going crazy
Grace - Reply Share
What type of cable did you use to replace the older one?
Mauricio Diaz - Reply Share
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 164
All Time: 3,862
