Lenovo Z70-80 Motherboard Replacement
Views: 5.2K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
84
All Time:
5,210
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide will demonstrate the step by step process on how to replace the motherboard in your Lenovo Z70-80.
Tools
    1. Lenovo Z70-80 Motherboard Replacement, Battery: step 1, image 1 of 2 Lenovo Z70-80 Motherboard Replacement, Battery: step 1, image 2 of 2
      • Use your fingers two push both latches away from each other to release the battery.
      • Pull the battery out.
      Ask FixBot
    1. Lenovo Z70-80 Motherboard Replacement, Back Panel: step 2, image 1 of 3 Lenovo Z70-80 Motherboard Replacement, Back Panel: step 2, image 2 of 3 Lenovo Z70-80 Motherboard Replacement, Back Panel: step 2, image 3 of 3
      • Remove the two Phillips #0 screws from the bottom panel.
      • Slide the panel down slightly, and then lift to pull it off.
      Ask FixBot
    1. Lenovo Z70-80 Motherboard Replacement, Optical Drive: step 3, image 1 of 3 Lenovo Z70-80 Motherboard Replacement, Optical Drive: step 3, image 2 of 3 Lenovo Z70-80 Motherboard Replacement, Optical Drive: step 3, image 3 of 3
      • Remove the single 3mm Phillips #0 screw from the optical drive.
      • Pull the optical drive out of the side.
      Ask FixBot
    1. Lenovo Z70-80 Motherboard Replacement, Electric Fan: step 4, image 1 of 3 Lenovo Z70-80 Motherboard Replacement, Electric Fan: step 4, image 2 of 3 Lenovo Z70-80 Motherboard Replacement, Electric Fan: step 4, image 3 of 3
      • Remove the three 6mm Phillips #0 screws from the fan.
      • Disconnect the fan from the motherboard by pulling up on the plug.
      Ask FixBot
    1. Lenovo Z70-80 Motherboard Replacement, Motherboard: step 5, image 1 of 1
      • Remove all the 17 7mm Phillips #0 screws.
      • A sticker covers this screw. Remove this sticker to remove the screw.
      • Remove the back cover.
      Ask FixBot
    2. Lenovo Z70-80 Motherboard Replacement: step 6, image 1 of 3 Lenovo Z70-80 Motherboard Replacement: step 6, image 2 of 3 Lenovo Z70-80 Motherboard Replacement: step 6, image 3 of 3
      • Pry the edges of the keyboard upwards using a spudger.
      • A cable with a ZIF connector is attached to the bottom of the keyboard. Flip the small black tab on the connector for safe removal.
      • Remove the five 3mm Phillips #0 screws.
      Ask FixBot
    3. Lenovo Z70-80 Motherboard Replacement: step 7, image 1 of 3 Lenovo Z70-80 Motherboard Replacement: step 7, image 2 of 3 Lenovo Z70-80 Motherboard Replacement: step 7, image 3 of 3
      • Remove all the ribbon cables and connectors from the front and back of the laptop.
      • Remember to flip the small black tabs on ZIF connectors for safe removal.
      Ask FixBot
    4. Lenovo Z70-80 Motherboard Replacement: step 8, image 1 of 2 Lenovo Z70-80 Motherboard Replacement: step 8, image 2 of 2
      • Remove the 3mm screw and carefully pull out the cables from the hooks holding them in place.
      Ask FixBot
    5. Lenovo Z70-80 Motherboard Replacement: step 9, image 1 of 2 Lenovo Z70-80 Motherboard Replacement: step 9, image 2 of 2
      • Use a spudger at the edges of the laptop cover to carefully pry upwards, removing the cover.
      Ask FixBot
    6. Lenovo Z70-80 Motherboard Replacement: step 10, image 1 of 3 Lenovo Z70-80 Motherboard Replacement: step 10, image 2 of 3 Lenovo Z70-80 Motherboard Replacement: step 10, image 3 of 3
      • Unplug the two black cables from the motherboard.
      • Remove the three 3mm screws from the motherboard.
      • Remove the motherboard.
      • Pick up the motherboard carefully by the edges.
      Ask FixBot
3 other people completed this guide.
Attached Documents
Eduardo Delgado
412 Reputation
4 Guides authored
Gateway, Team S1-G4, Johnson Spring 2018 Member of Gateway, Team S1-G4, Johnson Spring 2018
GCC-JOHNSON-S18S1G4
2 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 84
All Time: 5,210
