Lenovo Z70-80 Keyboard Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
56
All Time:
2,218
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide will demonstrate how to replace the keyboard on your Lenovo Z70-80 laptop.
Tools
  • Spudger
    4.9
    1. Lenovo Z70-80 Keyboard Replacement, Battery: step 1, image 1 of 2 Lenovo Z70-80 Keyboard Replacement, Battery: step 1, image 2 of 2
      • Use your fingers two push both latches away from each other to release the battery.
      • Pull the battery out.
      Ask FixBot
    1. Lenovo Z70-80 Keyboard Replacement, Keyboard: step 2, image 1 of 3 Lenovo Z70-80 Keyboard Replacement, Keyboard: step 2, image 2 of 3 Lenovo Z70-80 Keyboard Replacement, Keyboard: step 2, image 3 of 3
      • Carefully pry up the keyboard with the flat end of a spudger and remove all of the 3mm Phillips #0 screws.
      • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
      • Pull the keyboard cable out of the socket.
      • Remove the keyboard.
      Ask FixBot
Eduardo Delgado
412 Reputation
4 Guides authored
Gateway, Team S1-G4, Johnson Spring 2018 Member of Gateway, Team S1-G4, Johnson Spring 2018
GCC-JOHNSON-S18S1G4
2 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 56
All Time: 2,218
