Lenovo Yoga Tablet 2 830-F Camera Replacement
    1. Lenovo Yoga Tablet 2 830-F Camera Replacement, Camera: step 1, image 1 of 2 Lenovo Yoga Tablet 2 830-F Camera Replacement, Camera: step 1, image 2 of 2
      • Remove the three screws on the back of the device with the Phillips Screwdriver #00 bit.
      • Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
      Ask FixBot
    2. Lenovo Yoga Tablet 2 830-F Camera Replacement: step 2, image 1 of 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: step 2, image 2 of 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: step 2, image 3 of 3
      • Using the Phillips Screwdriver #00 bit remove the 6 screws.
      • Using the Phillips Screwdriver #00 bit remove the 3 screws.
      • After removing all the screws, disconnect the ribbon cables.
      • Disconnect the ZIF connectors.
      • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
      Ask FixBot
    3. Lenovo Yoga Tablet 2 830-F Camera Replacement: step 3, image 1 of 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: step 3, image 2 of 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: step 3, image 3 of 3
      • After removing the motherboard and antennas the camera module is located on the right as marked in red.
      • Remove the three 2mm screws holding the module in place with the Phillips Screwdriver #00 bit.
      • The camera module is also held in place with adhesive so gently remove.
      Ask FixBot
Mario Gjyli
461 Reputation
3 Guides authored
USF Tampa, Team S2-G4, Nance Fall 2017 Member of USF Tampa, Team S2-G4, Nance Fall 2017
USFT-NANCE-F17S2G4
3 Members
54 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 1,001
