Lenovo Yoga Tab 3 10 Wifi Module Replacement
    1. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Back Cover: step 1, image 1 of 1
      • Open the built-in kickstand.
      Ask FixBot
    2. Lenovo Yoga Tab 3 10 Wifi Module Replacement: step 2, image 1 of 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: step 2, image 2 of 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: step 2, image 3 of 3
      • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
      • Remove the microSD card slot cover. Remove any microSD card (if inserted).
      • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
      Ask FixBot
    3. Lenovo Yoga Tab 3 10 Wifi Module Replacement: step 3, image 1 of 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: step 3, image 2 of 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: step 3, image 3 of 3
      • Orient the device so the screen is facing you.
      • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
      • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
      • Some force will be required to detach the small plastic braces securing the backplate to the device.
      Ask FixBot
    1. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Wifi Module: step 4, image 1 of 2 Lenovo Yoga Tab 3 10 Wifi Module Replacement, Wifi Module: step 4, image 2 of 2
      • Use the nylon spudger to gently lift the foil cover of the wifi model.
      Ask FixBot
    2. Lenovo Yoga Tab 3 10 Wifi Module Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to gently lift the gold tape located above the copper foil.
      Ask FixBot
    3. Lenovo Yoga Tab 3 10 Wifi Module Replacement: step 6, image 1 of 1
      • Use the plastic spudger to disconnect the wifi module connector from the motherboard.
      Ask FixBot
    4. Lenovo Yoga Tab 3 10 Wifi Module Replacement: step 7, image 1 of 2 Lenovo Yoga Tab 3 10 Wifi Module Replacement: step 7, image 2 of 2
      • Carefully lift the wifi module from the device.
      Ask FixBot
Phanudej
1,208 Reputation
5 Guides authored
USF Tampa, Team S3-G2, Sullivan Spring 2017 Member of USF Tampa, Team S3-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G2
4 Members
54 Guides authored
1 Guide Comment
where can i buy this type of module?
rebeca rackolavsci - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 23
All Time: 4,200
