Lenovo Yoga Tab 3 10 Motherboard Replacement
    1. Lenovo Yoga Tab 3  10 Motherboard Replacement, Back Cover: step 1, image 1 of 1
      • Open the built-in kickstand.
      Ask FixBot
    2. Lenovo Yoga Tab 3  10 Motherboard Replacement: step 2, image 1 of 3 Lenovo Yoga Tab 3  10 Motherboard Replacement: step 2, image 2 of 3 Lenovo Yoga Tab 3  10 Motherboard Replacement: step 2, image 3 of 3
      • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
      • Remove the microSD card slot cover. Remove any microSD card (if inserted).
      • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
      Ask FixBot
    3. Lenovo Yoga Tab 3  10 Motherboard Replacement: step 3, image 1 of 3 Lenovo Yoga Tab 3  10 Motherboard Replacement: step 3, image 2 of 3 Lenovo Yoga Tab 3  10 Motherboard Replacement: step 3, image 3 of 3
      • Orient the device so the screen is facing you.
      • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
      • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
      • Some force will be required to detach the small plastic braces securing the backplate to the device.
      Ask FixBot
    1. Lenovo Yoga Tab 3  10 Motherboard Replacement, Motherboard: step 4, image 1 of 3 Lenovo Yoga Tab 3  10 Motherboard Replacement, Motherboard: step 4, image 2 of 3 Lenovo Yoga Tab 3  10 Motherboard Replacement, Motherboard: step 4, image 3 of 3
      • Locate the screws in the motherboard the wire cover assembly and the speakers.
      • Use the J000 screwdriver to remove the screws on the motherboard, the wire cover, and the two speakers.
      • Disconnect the wifi connector on the motherboard.
      Ask FixBot
    2. Lenovo Yoga Tab 3  10 Motherboard Replacement: step 5, image 1 of 2 Lenovo Yoga Tab 3  10 Motherboard Replacement: step 5, image 2 of 2
      • Use the spudger to lift the two speakers up from the small adhesive strip.
      • Place the spudger in the upper left corner of the motherboard and lift it to separate it from the adhesive strip under it.
      • Lift away the motherboard.
      Ask FixBot
15 other people completed this guide.
Phanudej
1,208 Reputation
5 Guides authored
USF Tampa, Team S3-G2, Sullivan Spring 2017 Member of USF Tampa, Team S3-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G2
4 Members
48 Guides authored
1 Guide Comment
Dear @phanudej ,
I liked your post. I’d have a remark and a question. I made a mistake during the maintanance; with wich I killed a part of the MOBO. So dear users my advice if you want to connect the LCD connector remove the battery before… I had never this issue but now happened. (the device was switched off)
Could you please take a photo of the powerstage of the LCD (I think it should be that) So between the inductor (100; 10uH coil) and an capacity there is a component I do not know what is it (it smoked away) I assume it is a diode…?! They are in the white rectangle near the LCD connector
Thanks in advance
Best regards
@harrincourt
Jozsef Szlatki - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 54
All Time: 10,180
