Lenovo Yoga 730-13IKB Touchscreen Display Replacement
    1. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement, Back Case: step 1, image 1 of 3 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement, Back Case: step 1, image 2 of 3 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement, Back Case: step 1, image 3 of 3
      • Power off the laptop and place it facedown on a non-scratching surface.
      • Remove the nine T5 screws fastening the back case.
      Ask FixBot
    2. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 2, image 1 of 3 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 2, image 2 of 3 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 2, image 3 of 3
      • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
      • Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
      • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
      Ask FixBot
    3. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 3, image 1 of 1
      • Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
      • Go slowly to avoid breaking any connecting tabs.
      Ask FixBot
    1. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement, Battery: step 4, image 1 of 2 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement, Battery: step 4, image 2 of 2
      • Remove the four 3.5mm Phillips #0 screws securing the battery.
      Ask FixBot
    2. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 5, image 1 of 3 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 5, image 2 of 3 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 5, image 3 of 3
      • Disconnect the battery cable by gently pulling it straight out of the connector.
      • The battery connector does not lock and requires light pressure to insert and remove. To reinstall the battery cable, hold onto the black housing and push it into the motherboard connector.
      Ask FixBot
    3. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 6, image 1 of 3 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 6, image 2 of 3 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 6, image 3 of 3
      • Remove the battery by pulling up near the white label and lifting diagonally away from the laptop.
      • Consider using a plastic opening tool to gently pry up near the white label if the battery seems stuck.
      • To reinstall the battery, carefully align its mounting holes with the plastic pins on the laptop frame.
      Ask FixBot
    1. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement, Heat Sink: step 7, image 1 of 2 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement, Heat Sink: step 7, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the eight 2.5mm screws securing the heat sink assembly.
      Ask FixBot
    2. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 8, image 1 of 2 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 8, image 2 of 2
      • Release the fan connector by gently pushing the gray locking tab up using a plastic spudger. Do this for both of the fans.
      • Pull each fan cable straight out of the connector.
      Ask FixBot
    3. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 9, image 1 of 1
      • Remove the heat sink assembly by holding the middle plate and rotating the assembly down towards the back of the motherboard.
      • Pull the heat sink diagonally away from the laptop.
      Ask FixBot
    1. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement, Touchpad: step 10, image 1 of 2 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement, Touchpad: step 10, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the six 2.5mm screws holding down the touch pad.
      Ask FixBot
    2. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 11, image 1 of 1
      • Peel back the fabric adhesive strap holding the speaker wire to the touchpad.
      • Using light heat from a hairdryer or heat gun may help loosen the adhesive.
      Ask FixBot
    3. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 12, image 1 of 1
      • Peel off the fingerprint sensor cable glued to the top of the touchpad.
      • Light heat from a hairdryer or heat gun may help loosen the adhesive.
      Ask FixBot
    4. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 13, image 1 of 1
      • Slightly pull up the metal strap connecting the touchpad and the laptop frame.
      • The metal strap is not glued down and only needs to be disconnected, not removed, from the laptop frame.
      Ask FixBot
    5. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 14, image 1 of 3 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 14, image 2 of 3 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 14, image 3 of 3
      • Peel the yellow tape off of the touchpad connector.
      • Gently push the gray tab up on the connector using a spudger. Pull out the cable.
      Ask FixBot
    6. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 15, image 1 of 1
      • Hold the top of the touchpad and gently pull up.
      • Lift the touchpad diagonally away from the laptop.
      • The laptop screen is now visible through the touchpad cutout. Be careful not to drop anything on it.
      Ask FixBot
    1. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement, Motherboard: step 16, image 1 of 2 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement, Motherboard: step 16, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the five 3.5mm screws securing the motherboard.
      Ask FixBot
    2. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 17, image 1 of 1
      • Use a Phillips #000 driver to remove the four 3mm screws holding down the connector bracket.
      Ask FixBot
    3. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 18, image 1 of 1
      • Lift the bracket up from the motherboard and place aside.
      Ask FixBot
    4. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 19, image 1 of 1
      • Use a spudger to remove the bluetooth cable by flipping up the gray connector tab. Pull out the cable.
      Ask FixBot
    5. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 20, image 1 of 1
      • Use a spudger to remove the fingerprint sensor cable by flipping up the gray connector tab. Pull out the cable.
      Ask FixBot
    6. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 21, image 1 of 1
      • Use a spudger to remove the keyboard cable by flipping up the gray connector tab. Pull out the cable.
      Ask FixBot
    7. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 22, image 1 of 2 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 22, image 2 of 2
      • Peel the black adhesive strip covering the wires to the LAN card.
      • Keep the adhesive strip for when you reconnect the LAN card.
      Ask FixBot
    8. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 23, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the 2.5mm screw securing the LAN card.
      Ask FixBot
    9. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 24, image 1 of 2 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 24, image 2 of 2
      • Gently slide the LAN card straight out of the motherboard connector.
      Ask FixBot
    10. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 25, image 1 of 1
      • Disconnect the black and white wires from the LAN card.
      • The black and white wires attach to the LAN card using a button-style clasp.
      • To reinstall the wires on the LAN card, push down on the wire connector until it clicks.
      Ask FixBot
    11. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 26, image 1 of 1
      • Peel back the adhesive cover connecting the display connector and hinge.
      Ask FixBot
    12. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 27, image 1 of 1
      • Lift the display connector straight up from the motherboard.
      • Use the black pull tab on top of the display connector for more leverage.
      • To reinstall the display connector, push it straight down. You may not hear an audible click, but make sure the connector is securely seated.
      Ask FixBot
    13. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 28, image 1 of 1
      • Remove the motherboard by holding it by the bottom and pulling diagonally away from the laptop.
      Ask FixBot
    1. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement, Touchscreen Display: step 29, image 1 of 2 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement, Touchscreen Display: step 29, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the four 4mm display hinge screws.
      Ask FixBot
    2. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 30, image 1 of 3 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 30, image 2 of 3 Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 30, image 3 of 3
      • Rotate the screen hinge next to the LAN card away from the laptop frame.
      • Pull the black LAN card wire through the hinge and unhook it from the holding tabs.
      Ask FixBot
    3. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 31, image 1 of 1
      • Rotate the screen hinge above the display connector away from the laptop frame.
      • Pull the black display cable bundle through the hinge.
      Ask FixBot
    4. Lenovo Yoga 730-13IKB Touchscreen Display  Replacement: step 32, image 1 of 1
      • Lift the touchscreen back and up to unhook the hinges from the laptop frame.
      Ask FixBot
Ethan Wagner
549 Reputation
3 Guides authored
Cal Poly, Team S1-G1, White Winter 2020 Member of Cal Poly, Team S1-G1, White Winter 2020
CPSU-WHITE-W20S1G1
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 101
All Time: 6,860
